Old 04-07-2019, 12:36 AM   #1
CMars45000
CMars45000's Avatar
Difference between Hydroboost units?
It there any difference between most hydro boost units available in a junk yard? I mean, if I can adapt it to the firewall, and use the correct M/C, I can use anything I'd like, correct?
What is the deal with some of the hydroboost units from SUVs having a larger accumulator cylinder? What is the purpose of it? It is work considering (or avoiding?)
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 04-09-2019, 07:17 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Difference between Hydroboost units?
there are differences...i cant list and dont know all of them....just get a complete unit from whatever you choose...i know pushrods seem to be a issue ,so its better to get it complete
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-10-2019, 12:18 AM   #3
CMars45000
CMars45000's Avatar
The pushrod between the booster and the master or the from the pedal to the booster?
I guess the basis of my question was if there was a "better" application than another to seek for the swap.
Vehicles/Projects:
-Aristotle
Old 04-10-2019, 12:34 AM   #4
mongocanfly
Post Whore
the rod between the master and the boost is the one...
what are you wanting to put it on? ive got one on my c30 and love it
ive also put one on my IH build and it belongs to a c20-30 series truck from the 80s...I got this one mainly based on the IH being a 3/4ton
I know some guys use them from astro vans on the AD trucks
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-10-2019, 10:35 AM   #5
CMars45000
CMars45000's Avatar
It is going on a 1971 C10 2wd. The truck has manual brakes now. I was going to have an expense to go to power either way, so I figured I'd just go strait to hydro
Vehicles/Projects:
-Aristotle
Old 04-17-2019, 10:36 AM   #6
ABHaulR
ABHaulR's Avatar
Ive used both, 1 ton hydro and astro van. Both work great. Just make sure you get the parts all from one donor. ie van or 1ton.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 04-17-2019, 10:55 AM   #7
Bigdav160
Bigdav160's Avatar
I have an Astro unit installed on my truck. I did notice that the accumulator is twice as long on a newer Suburban in the shop.
My guess is that it allows more power applications of the brakes without
hydraulic pressure in an emergency.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-19-2019, 10:19 AM   #8
CMars45000
CMars45000's Avatar
That's a valid point. I hadn't thought about that. I ended up getting an entire setup from a 2008 Silverado HD. My concern now is that Mater cylinder bore might be too large for D52 style calipers in my application.
The Master bore is 37mm (1.45"). Wouldn't this yield a very stiff pedal, all other things being equal?
Vehicles/Projects:
-Aristotle
Old 07-17-2019, 08:33 AM   #9
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing this back up. I have a 2005 hydro-boost setup on my Blazer. I do have upgraded brakes on all 4 corners. My understanding is MC bore size affects pedal firmness and pedal travel inversely proportional.
The biggest aftermarket MC I can find is 1.125 (1 1/8th) compared to the 1.45 (1/ 716th)
Rich
1972 K5 Blazer CST Click HERE
Old 07-19-2019, 05:02 PM   #10
Bigdav160
Bigdav160's Avatar
Non-power assisted brakes will have a smaller bore than power assisted brakes to give more hydraulic advantage at the expense of slightly longer travel. Like 1" vs a 1 1/8" or 1 1/4"
A hydro-boosted setup you could probably get away with a larger bore just because of how much assist the hydroboost gives.
I am using my OE 1972 3/4 ton MC on my hydroboost.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
hydroboost
