Old 04-09-2019, 02:23 AM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
Last project 1964 C10
Here is a run down of my 1964 C-10 project. I just turned 60 yrs old and I think this will be my last build..so I maybe dump a bit more effort into it.
I started with a short bed frame I found on CL for $125.00 and added a Porterbuild suspension kit , 496 big block with FiTech EFI and Jones Racing pulley system , Turbo 400 Gear Vendors Overdrive and a fresh 12 bolt Posi.
I swapped in a Big back window and every panel is brand new..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 04-09-2019, 02:25 AM   #2
ol_skool_chevy
Re: Last project 1964 C10
Mark with Chalk
Cut with a torch
Old 04-09-2019, 02:28 AM   #3
ol_skool_chevy
I took it to one painter and he made a mess of it so its now at a new shop..
Mark with Chalk
Cut with a torch
Old 04-09-2019, 02:31 AM   #4
ol_skool_chevy
This is fresh out of paint at the new shop...Im not sure how nice it is these photos were send to me. I am in the Philippines right now with the wife..
Mark with Chalk
Cut with a torch
Old 04-09-2019, 07:17 PM   #5
slimjim66
looks good, keep up the work
slimjim66 is offline   Reply With Quote
Old 04-10-2019, 01:21 AM   #6
Captainfab
60-66 Nut
That looks awesome!
Old 04-10-2019, 06:52 AM   #7
ol_skool_chevy
Originally Posted by Captainfab View Post
That looks awesome!
Thank you...I did use your rear disk brake adapters with Wilwood d-52's
Mark with Chalk
Cut with a torch
Old 04-10-2019, 10:31 AM   #8
Bomp
Bomp's Avatar
Glad to see you got the truck together. Looks really good.
Bomp is offline   Reply With Quote
Old 04-10-2019, 07:48 PM   #9
ol_skool_chevy
well . it's taken the painters a year to get color on it....not all together yet
Mark with Chalk
Cut with a torch
Old 04-10-2019, 08:17 PM   #10
Mack B
Mack B's Avatar
I really like what you are doing with this one. These trucks look amazing in black.
What size wheels and tires is that?
Mack B is offline   Reply With Quote
Old 04-13-2019, 04:05 PM   #11
Ronzo
Ronzo's Avatar
That looks incredible, well done.
Ronzo is offline   Reply With Quote
Old 04-14-2019, 10:16 AM   #12
DCLefler
It looks great! I hope you don't mind picking your brain a little. What kind of header did you use? Did you move the engine forward and what about valve cover clearance?
I am just about to start on my 65 swb I have all the parts to start just need a few more things headers being one of them.
DCLefler is offline   Reply With Quote
Old 04-16-2019, 06:12 PM   #13
SCOTI
SCOTI's Avatar
Nice.... Old school build using new tech. I like it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-27-2019, 05:19 AM   #14
ol_skool_chevy
275-70-15 on 15x8,5 rims in rear.
Mark with Chalk
Cut with a torch
Old 04-27-2019, 05:24 AM   #15
ol_skool_chevy
I used a BBC Chevelle Patriot headers I did not move the engine forward..the rack and pinion steering will not allow for that very very tight to the oil pan. there was no clearance for the valve covers to clear the firewall. I had to heat the firewall up and hammer it back enough to clear..plus the motor sets higher and no room for a power brake booster..I had to use a Hydroboost
Mark with Chalk
Cut with a torch
Old 04-27-2019, 06:57 AM   #16
lolife99
67-72 parts collector,…
lolife99's Avatar
Awesome build.
Very cool everything!
Keith
Convert to disc brakes.
