Old 05-06-2019, 07:36 PM   #1
catch2otwo
pancake/sectioned crossmember question
So I am installing a 1978 c30 crossmember that I sectioned 1.5" out of. Its being installed in my 68 c10. The three vertical holes lined up no problem. The two bolts that go through the side of the frame dont line up with the holes in the frame anymore and only partially line up with the holes that are close to it.
What is everyone doing? welding up the partial holes and re-drilling in the right location?
catch2otwo is offline   Reply With Quote
Old 05-06-2019, 08:58 PM   #2
tinydb84
tinydb84's Avatar
Re: pancake/sectioned crossmember question
Usually drill new holes. Ive seen a few people weld in threaded bungs to the very top bolts when there are partially lined up with the frame and you dont habe enough frame to drill a proper hole.
David
Instagram: myfabguy
Old 05-06-2019, 10:19 PM   #3
catch2otwo
copy that, ill fill the existing holes and redrill the new ones.
PS your work looks awesome! ill have to remember you as a local resource
Old 05-08-2019, 02:40 PM   #4
tinydb84
tinydb84's Avatar
Thank you sir. I didn't even notice the SF. Let me know if you ever need a hand.
David
Instagram: myfabguy
