Old 05-31-2019, 11:56 AM   #1
G-NUT
G-NUT's Avatar
700r4 fluid capacity on fluid and filter change
I'm planning on changing my 1984 C10 Suburban transmission fluid and filter. Any recommendations. This will be the first time I've performed this on this vehicle and on a 700r4. I just got this burb. Fluid type, Dextron III from what all I've found. How many qts?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 05-31-2019, 01:18 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 700r4 fluid capacity on fluid and filter change
https://www.tciauto.com/fluid-capacity
Old 05-31-2019, 01:32 PM   #3
61K10
61K10's Avatar
to start put back in the amount you drained out.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-17-2019, 06:24 PM   #4
Sparky dave
If it’s just an oil change not a flush do as stated above drain it out and measure it. I think about 6-7 litres went in mine but I might have a big aftermarket sump. When checking your dip stick oil level don’t forget to check it warm with the engine running in neutral. Also a good time to check your tv cable adjustment. I’ve just done all this with mine a couple of weeks ago
Sparky dave is offline   Reply With Quote
700r4, flush, transmission fluid
