Old 06-03-2019, 07:06 PM   #1
Fawnzie
Fawnzie's Avatar
Fawnzie
What started out as a simple engine swap kinda got outta hand. Word of advice, NEVER pull the front clip off to put the engine in! Once it's off you'll see things that you'll want to replace, change or redo. Sooooooo this simple weekend engine swap turned in to a full frame off. New air ride, engine, paint, A/C, you get the idea. Made a quick trip to MaxBuilt Autoworks and the rest is history. This shop is top notch! And now, here come the pics. Here's what I started with.
Fawnzie is offline   Reply With Quote
Old 06-03-2019, 07:12 PM   #2
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Now right about here is where things got outta hand.
Old 06-03-2019, 07:18 PM   #3
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Okay, replacing the control arms seems pretty easy, also should probably convert the front to disc brakes. Lets add some rims too.
Old 06-03-2019, 07:21 PM   #4
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
After putting everything back together the static drop i had, I kinda over calculated. Pancaked crossmember, 2.5" drop spindles and drop coils with a coil cut was a bit much. f#!k it, lets just bag the thing!
Old 06-03-2019, 07:21 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fawnzie
Wow those Cragars look good on there. Ya it gets away from you.
Old 06-04-2019, 07:47 PM   #6
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Loaded on the trailer and headed to Indio, CA to Maxbuilt Autoworks. The engine you see is the first replacement engine, a 350 that I put in. Needless to say it wasn't in there long.
Old 06-04-2019, 07:50 PM   #7
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Once I got to Maxbuilt Autoworks, they made quick work of getting the front end striped down.
Old 06-04-2019, 07:55 PM   #8
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Got a big pile of Porterbuilt parts. Did some test fitting as well.
Old 06-04-2019, 07:59 PM   #9
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
more test fitting
Old 06-07-2019, 11:13 AM   #10
youngrodder
youngrodder's Avatar
Re: Fawnzie
Driving them is overrated.....haha
Looks like you are going in the right direction..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-07-2019, 11:25 AM   #11
Warrens69GMC
Warrens69GMC's Avatar
Re: Fawnzie
Your wallet screaming yet?
Old 06-07-2019, 02:34 PM   #12
Android04
Android04's Avatar
Re: Fawnzie
My wallet hurts just from reading this... aka I'm jealous
Android04 is offline   Reply With Quote
Old 06-08-2019, 10:03 AM   #13
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Wallet? What wallet?? haha It exploded
Old 06-08-2019, 10:18 AM   #14
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
This is where its at. Chassis is completely stripped down
Old 06-08-2019, 11:11 AM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Fawnzie
Man! That takes guts imo! Take a good looking driver and blow it apart. I’m in to see the progress!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-08-2019, 03:02 PM   #16
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Thanks Clyde! I wasn't going to do this. I just wanted to do a simple engine swap!
Old 06-08-2019, 04:52 PM   #17
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Here's my new replacement engine. 383 stroker 477hp with a triple deuce. A lil engine porn if you will.
Old 06-09-2019, 09:57 PM   #18
youngrodder
Re: Fawnzie
Great looking engine. Cant go wrong with 3 deuces....
Marc
Old 06-09-2019, 10:53 PM   #19
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Got the firewall smoothed out. The firewall panels are made by Slosh tubs. Great quality, I highly recommend.
Old 06-11-2019, 11:20 AM   #20
Duncan K
Re: Fawnzie
That firewall looks awesome!!
66 GMC 910
My Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=754257
Duncan K is offline   Reply With Quote
Old 06-11-2019, 11:55 AM   #21
Android04
Android04's Avatar
Re: Fawnzie
Old 06-12-2019, 11:14 AM   #22
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Thanks! I'm running out there today to drop off the 700r4 and the headers. I'm gonna grab a bunch more pics. the body should be in primer and the chassis should almost be done. For the cali guys, it will be at the Brothers truck show on July 7th. Done or not it'll be in MaxBuilt's booth.
Old 06-12-2019, 08:16 PM   #23
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Got the back half on and working on the front end. Next is taking it all apart and getting it to the paint booth
Old 06-13-2019, 06:18 PM   #24
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Into the spray booth. Got the chassis torn down and ready for paint.
Old 06-19-2019, 06:19 PM   #25
Fawnzie
Fawnzie's Avatar
Re: Fawnzie
Got the frame assembled and the suspension on.
