Front brake dragging, 83 GMC
Truck is an 83 GMC, not driven much (@38K miles on it). Last week while in town I noticed the left front brake was dragging.
Given the age and what I found nosing around here, figure it's time to replace the rubber lines, and probably do calipers, pads, and maybe rotors at the same time. AC Delco lines are cheap enough (@$12 each on Rockauto). What kind of calipers and pads do yall recommend? Looks like Delco sells a caliper/hardware/semi metallic pad set, but from what I've heard Delco isn't what it used to be, and these might just be the same crap Chinese parts in a fancy Delco box. Suggestions? |
#2 | |
Re: Front brake dragging, 83 GMC
For brake stuff, I like Raybestos & Wagner products & use them when possible. Otherwise, house brand w/the best warranty offered.
I have been wanting to change my rubber hoses on truck but man do those look like a real pain to get to. I am putting this off as long as I can.
79 Chevy 2wd BIG10 350 TH400 |
On a 'Squarebody', they're actually not too bad. Banjo fitting @ the caliper & bulkhead fitting @ the frame. Both are pretty accessible.
Post Whore
![]() ![]() Join Date: May 2015
And if you decide to change the hoses be sure to use a proportional valve centering tool before you start bleeding brakes...
67-72 parts collector,
![]() Join Date: Nov 2002
And remember there are two different width rotors available for these trucks.
1-1/4” hd rotors and the light duty 1” rotors. Calipers and bearings are also different.
I've noticed that most calipers say they're for 11" by 2" rotors OR the regular rotors.
Does that mean heavy duty calipers will fit all rotors, but light duty calipers will not fit the HD rotors? |
#9 | |
HD calipers only fit the 1-1/4” rotors. Calipers have to match the rotors. Rotors have to match the spindles. And there’s 2 different spindles also. No such thing as a 2” wide rotor.
#10 | |
Moderator
![]() Join Date: Oct 2008
AMC seemed to use the same parts as the big three in a lot of places. They were operating on a shoestring budget for several decades before they went under. The 258 in my Eagle wagon used Ford Duraspark ignition parts and a Carter BBD carburetor that many folks swapped out for the Motorcraft 2100 or 2150. The BBD was used on many Chryslers.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#11 | |
I used a hotter coil and bigger cap/rotor on my Duraspark ignitions on mine. https://www.jeep-cj.com/forums/f2/te...e-11416-print/ I really like those Eagle rigs. Used to be everywhere and cheap, but looks like they're becoming a niche collector car now. |
#12 | |
ACDELCO 18R640 {#18035829} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info FitsFront Left; with 11-5/32in x 2-3/4in Brakes OrFront Left; Heavy Duty System; w/ 11" X 2" Brakes ACDELCO 18R639 {#18035828} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info FitsFront Right; with 11-5/32in x 2-3/4in Brakes OrFront Right; Heavy Duty System; w/ 11" X 2" Brakes ACDELCO 18R623 {#18035812, 18R737} Professional; Non-Coated, Includes: Semi-Metallic Pads and Hardware; Reman. Info One of our most popular parts Front Right; Standard System; w/ 11" X 2" Brakes |
#13 | |
Go out to your truck and measure your rotor width first. Per RockAuto,... It looks like 18FR623 and 18FR624 are for the light duty 1" rotors. And 18FR639 and 18FR640 are for the HD 1-1/4" rotors.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-28-2019 at 02:51 PM. |
#14 |
Look at this thread also:
http://67-72chevytrucks.com/vboard/s...d.php?t=209390 A lot of parts stores show JB3 or JB5 when referring to brake parts,... QUOTE: JB3 is the 1" thick rotors JB5 is the 1.25" thick rotors
#15 | |
#16 |
the hardest part i had when doing the brakes was that stupid stamped steel nut to unscrew from the rubber brake line that sucked so bad i ended up cutting the rear metal brake line and going to the store and making a new metal line and then i used the stainless steel flex hoses the stopping power is so amazing now. I just did a complete brake job on my suburban and i had to find the correct master mine took the jb6. i know that the banjo bolt do not fit into both the 1" caliper and the 1.25 caliper they are different and the hole inside the bolt is way bigger on the 1.25 than the 1 inch. fyi
