Old 06-30-2019, 05:36 PM   #1
Jrainman
Jrainman's Avatar
front wheel well 73-80 vs 81-87
was worndering the diffrerance between the inner wheel wells 73-80 vs 81-87
Jrainman is offline   Reply With Quote
Old 06-30-2019, 11:00 PM   #2
WyattTX
Re: front wheel well 73-80 vs 81-87
The entire front fender, and hood is different, nothing interchanges between the 73-80 Front clip, and 81-87 front clip, except hood ornaments. Wheel wells would likely be of similar depth, since the front suspension design remained the same.
WyattTX is offline   Reply With Quote
Old 07-01-2019, 07:30 AM   #3
Dead Parrot
You can get a 81-87 passenger side inner wheel well to fit a 73-80 fender. Learned this after an old style 'you can't go back there' salvage yard sold me the newer style for my 75 many years ago. Naturally there was a 'all sales final' policy.
After a bit of cussing, got it to fit. Most of the holes will line up. Had to drill a couple new ones. The battery tray support is in a different and lower spot. Good enough for a functional replacement but not for a show quality fix up.
Guessing the driver's side is similar but haven't had to test that.
Dead Parrot is offline   Reply With Quote
Old 07-01-2019, 07:53 AM   #4
bluex
bluex's Avatar
The shape is slightly different an 73-80 inner will give you a little more room than an 81-87. The inners you can swap around between years like mentioned above you just might have to drill or open up some holes.
bluex is offline   Reply With Quote
