Old 10-14-2019, 05:06 AM   #1
kens65fb
Ignition switch connector ?
I have looked everywhere, I can't find a source for the plastic connector for the ignition switch. My switch was jury rigged with connectors, and I would like to utilize the factory connector, any help ?
I searched the parts for sale section, and I couldn't find one.
kens65fb is offline   Reply With Quote
Old 10-14-2019, 10:30 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Ignition switch connector ?
Have you checked with American Autowire?
Or better yet M&H - http://www.wiringharness.com/
Old 10-14-2019, 12:28 PM   #3
kens65fb
I checked both of them, and neither has a connector for sale.
I was hoping a member, who has rewired using a new harness, might sell me one.
Old 01-24-2021, 02:14 PM   #4
shsahs
shsahs's Avatar
Hey I know its been awhile since this thread was started but I am looking for the same part. Did you ever find this? If so would you share where.
shsahs is offline   Reply With Quote
Old 01-24-2021, 02:24 PM   #5
The Rocknrod
Moderator
Does this work? https://www.classicindustries.com/pr...MaAs0DEALw_wcB
Here is the one from AAW - https://smhttp-ssl-87263.nexcesscdn....632_IN_0.0.pdf
Old 01-24-2021, 07:02 PM   #6
shsahs
shsahs's Avatar
This is exactly what I have. Thanks for getting me close. But I didn't see where I could purchase the connector.
I may give them a call during the week and see if they offer one. If not I just purchased a 65 C20 today that we may part out. I haven't even looked under the dash but the key looked like it hadn't been messed with. I just didn't want to get in the rat turds with the live rat that was still there to look under the dash.
Old 01-25-2021, 11:30 AM   #7
The Rocknrod
Moderator
Did you find one? I may one in my shop, let me look.
Does this look about right?
Old 01-25-2021, 12:28 PM   #8
shsahs
shsahs's Avatar
Yes it does look correct. How much $ would you like for it?
Old 01-25-2021, 12:54 PM   #9
The Rocknrod
Moderator
Well you know these things are like hens teeth and the next series goes for over $30 on eBay...
PM me you address and I'll get it out from USPS in a day or two. You can somehow remit the postage. I'll never use it, been in my shop for 4 years.
Old 01-25-2021, 01:28 PM   #10
shsahs
shsahs's Avatar
Let me check this 65 truck we just bought yesterday and see if its the correct one first. If its the correct one there is no need to ship me one. We just dropped it out on our land so it will probably be this weekend before I get to go look at it. If that is ok.
Old 01-25-2021, 07:08 PM   #11
The Rocknrod
Moderator
You'd think that the 510632 number on they're drawing would indicate a part number they would sell. They have them obviously. Oh I just checked, that's the number for their ignition switch I guess. Not the connector.
Old 01-25-2021, 08:11 PM   #12
shsahs
shsahs's Avatar
I had called Standard Motor Products the other day as they seem to sell a lot of factory switches and pigtails. I got the impression the guy thought I just couldn't find it or was to lazy to look. After a few minutes he comes back with ya know we don't make that one. He was sort of like at a loss for words as if he couldn't believe they didn't either.
It is odd that this one switch seems to have been neglected when it comes to the aftermarket replacement plug.
Old 01-25-2021, 08:24 PM   #13
MT65
If Rocknrod doesn’t have one, I may, just rewired a 65, pulled stock everything....let me know
MT65 is offline   Reply With Quote
Old 03-19-2021, 11:00 PM   #14
shsahs
shsahs's Avatar
I finally made it out to the 65 we had picked up. The switch and plug were there.
Now my search is for the brass ends that go on the ends of the wires. I don't want to splice all the wires to this plug. I would like new connectors in the plug on the ends of the wires. Does anyone know where to get these?
I would take these out and open them and reuse if I have to but really do not want to go through that.
My 1966 Chevrolet C10 Pickup
Old 03-19-2021, 11:31 PM   #15
MT65
A parts house may have them, I get them from a couple electrical suppliers, or with new harnesses that I install. You can remove the terminal with a flat hair pin or similar if you don’t have the correct tool.
Looking into the connector there is a retaining clip that holds them in place, releasing that will let you get one out for and example at the parts house.
If they are without them, send me a picture and I can send you some ...
Old 03-20-2021, 12:00 AM   #16
shsahs
shsahs's Avatar
Thanks I appreciate the info and offer.
Ill try Monday at our better parts houses. I doubt Autozone or O'Reilly will be a good effort.
Old 03-20-2021, 09:09 AM   #17
The Rocknrod
Moderator
You looking for this kind of stuff? - https://www.repairconnector.com/pack...-and-housings/
Old 03-20-2021, 09:16 AM   #18
shsahs
shsahs's Avatar
Thats what I was looking for. Thank you very much.
Old 10-24-2023, 07:39 PM   #19
JPTL
Old thread resurrection...
Is the consensus that this connector isn't readily available? My wiring was hacked up when the p/o put in a universal ignition switch. I'd like to get back to something closer to stock and rewire to the original connector.
JPTL is offline   Reply With Quote
Old 10-29-2023, 12:43 AM   #20
gmtech68
I just did some digging myself. American Autowire sells the connector along with the terminals eith a switch. Not sure if they would sell it separately.
gmtech68 is offline   Reply With Quote
