12-27-2019, 02:13 PM | #1 |
Best front end Drum to Disc break conversion kit?
I need to buy the best and most complete kit to upgrade my 1970 CST, C20 3/4 ton pickup that has 8-lug drum brakes. I've just looked at BROTHERS 8-lug "DELUXE" disc brake conversion kit and POL's C20 Truck Disc Brake Conversion, 8-Lug Deluxe. Between these two and any other recommendations you may have, what is the best for safety, reliability, and durability (cost is not an option)? Thanks.
12-27-2019, 02:29 PM | #2 |
Re: Best front end Drum to Disc break conversion kit?
This link is a (Sticky) found in the Suspension forum.
Hope it helps. Link: http://67-72chevytrucks.com/vboard/s...68&postcount=4 Original Link:http://67-72chevytrucks.com/vboard/s...d.php?t=444823 .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
12-27-2019, 03:34 PM | #3 |
67-72 parts collector,…
I recommend ECE.
www.earlyclassic.com They have been in the business longer than just about everyone.
12-27-2019, 08:47 PM | #4 |
Thanks Gentlemen. Now another separate inquiry. Which is better, a 5-lug vs 6-lug? Is the 6-lug more heavy duty or is it just your preference for wheel options?
12-27-2019, 09:14 PM | #5 |
Great question.
I think it is personal preference. With 5 lug you will have A lot more wheel options. My choice of 5 or 6 lug would be 5 lug. Around 1970 they started 5 lug option for chevy trucks. If you are not going to use and abuse this truck , 5 lug would be my choice . Go with 8 lug if you want Heavy Duty. .
12-28-2019, 11:07 AM | #6 |
Benefit of going 6 lug is not having to change your axles or drums out back. That's the route I took. If you decide later you want some 5 spoke wheels you can change to 5 lug then.
12-28-2019, 04:18 PM | #7 |
Thanks. For right now I'm just changing the fronts to disc for more stopping force cause the other day I went through an intersection with the foot through the floor trying to stop the beast. I love the truck, I want to be safe, and never have this happen again. So, for the fronts from the great info you folks provided - saving me time - I'm going with 6-lug or 8-lug disc on the front. I still haven't decided who to buy them from since they all have discount specials going on right now. Thanks again gentlemen!
Tags |
1970 c20, disc brake conversion |
