Old 02-05-2020, 11:24 PM   #1
skip99
skip99's Avatar
Speedway drop spindles, must 2
Installed speedway 2” drop spindles, and gm disc conversion, im not sure it is even an issue, but it seems that where the caliper slide bolt hits the rear strut bar it kinda limits how far i can turn, if measure at the steering linkage in front of spindle, it moves about 3”, I checked the power rack and it travels about 4”, but im not sure how far is normal for a spindle
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 02-06-2020, 09:28 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Speedway drop spindles, must 2
What lower A-Arms is that? Is that a Mustang II suspension you installed?
Old 02-06-2020, 10:06 AM   #3
skip99
skip99's Avatar
Mustang 2
Tami's 51 build
Old 02-07-2020, 09:33 AM   #4
PGSigns
PGSigns's Avatar
Most of the mustang 2 stuff we used to use in drag cars was front steer. It looks like you are set up for rear steer. That may be the problem.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-07-2020, 10:01 AM   #5
skip99
skip99's Avatar
Jimmy
Nope, front steer, but looks like i have plenty of turning radius, so shouldnt be an issue
Tami's 51 build
Old 02-07-2020, 11:05 AM   #6
oldman3
oldman3's Avatar
Hey Skip, I've been trying to find pics of my 32 Chevy with MII, dropped spindles and the stock lower control arm with strud rod back to frame. I know I never had problems with anything hitting, but I had Heidt's dropped spindles. If you still have my number give me a call...Jim
oldman3 is offline   Reply With Quote
Old 02-09-2020, 11:21 AM   #7
oldman3
oldman3's Avatar
Finally found a couple pics. For us old guys we are used to seeing the original MII with the stock lower arms. 74-78 Mustang and Pinto front end were the ticket back in the 80's. They were about the right width for many street rods. The orginal lower arm fit inside the crossmember with a bolt to hold in place, and a strut rod to anchor arm to the frame. As the MII caught on it change to what we see today with the larger lower arm with gussets welded to the crossmember, etc.
Just wanted to throw this out there in cause someone needed to know.
First pic is from some instruction on how to install in a 41-48 Ford.
second pic is of my 32 Chevy, first put the MII in it around 1986, and this pic is around 1992 when I redid the whole car...Jim
