03-03-2020, 09:01 AM | #1 |
Suspension Crap
About to get under here and install the Belltech lowering kit. What are you guys using to remove these years of gunk and crap buildup?
Posted via Mobile Device |
03-03-2020, 09:19 AM | #2 |
Re: Suspension Crap
Engine cleaner soak and pressure washer is what I used. Still have to scrub some spots. Yours doesn't really look too bad really.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
03-03-2020, 09:26 AM | #3 |
Moderator
Re: Suspension Crap
Yep, then a wire brush. Or even a wire wheel if need be. Not bad, goes fast. Wear eye protection, that crap gets ballistic.
03-03-2020, 09:53 AM | #4 |
Re: Suspension Crap
Does brake cleaner work also? I have a few cans of that.
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
03-03-2020, 10:08 AM | #5 |
Moderator
Re: Suspension Crap
Try it. I mean nothing is going to disappear for you. Your still going to have to wire brush it.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-03-2020 at 10:14 AM. |
03-03-2020, 10:56 AM | #6 |
Re: Suspension Crap
I don't mind the work...just want to use something that does a good job of loosening it up since I don't have a pressure washer.
03-03-2020, 11:41 AM | #7 |
Re: Suspension Crap
I would get in there with a screwdriver or scraper and loosen/remove all the big crap that you can and then wire wheel/brush what you can and then soak spray it down really heavy with something like simple green or the like and let it sit for a couple hours then start back at the beginning of the process to remove what has been loosened. If you have a wire wheel on a grinder you should be able to get most everything off pretty easy before soaking but like mentioned above wear some PPE that crap flies everywhere. Spraying with anything before removing as much of the big chunks is just a waste in my opinion because it will never be able to penetrate deep enough to where you need it with a thick layer of grease and road grime on there.
03-03-2020, 06:03 PM | #8 |
Re: Suspension Crap
My .02 is a little more extreme. I would pull all the parts off the front suspension and sand blast them.
Depending on your goals maybe scrap the tie rod end for new ones. Are the ball joints original? If so I would look at replacing. If they have been replaced they should be bolt on so they could unbolted before sand blasting the arms. |
