08-28-2020, 06:37 AM | #1 |
70+ ( Old Skool Club )
Hopefully this Board fixes my Tach problem
Seen some recent post of the forums here about tachs not reading right cause of HEI's. Couple people mentioned they tried these and it cured their problem. I have a Petronix Distributor in my truck and wrote the seller before I ordered the new board and he said it should work. I will post and let everyone know how it works once installed.
https://www.ebay.ca/itm/Tachometer-C...53.m1438.l2649
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-28-2020, 08:15 AM | #2 |
Proprietor of Dale's Corner
Re: Hopefully this Board fixes my Tach problem
Hopefully it works, let us know how it goes.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-28-2020, 08:42 AM | #3 |
The Older Generation
I bought a 6 cylinder board from them and rebuilt a non working 8 cylinder tach with it, for my Green '67. So far it is working good. The only problem I had was removing the mounting studs from the old board and installing in the new one. If I do another one I would figure out something different for that. I think Andy rebuilt one with one of their boards also. LockDoc
08-28-2020, 09:18 AM | #4 |
I’m running the same setup, though I have the Mallory version.
It sounds like the board you’re replacing is the issue to begin with. I had a factory Tach in my truck and then did the Points to Electronic conversion. I was expecting issues, but everything worked fine. Fast forward twenty years. One day my Tach Just started acting erratically, bouncing at first then reading low. So I ordered and installed a new one. Problem solved. Only after I did this, did another board member (Andy) is Find the mother board that is on your post. I could have saved about $40 I am going to order oNe of these to fix my original, just to have one on hand for a future project truck. |
08-28-2020, 04:39 PM | #5 |
Old member
Here is the thread I did a few months ago on this. Mine is working great with the HEI. The original tach worked also but started giving me trouble.
http://67-72chevytrucks.com/vboard/s...d.php?t=803315
08-28-2020, 06:08 PM | #6 |
Cool, another vendor supporting a 50 year old class vehicle.
This is good news, let us know how it goes! |
08-29-2020, 08:44 PM | #7 |
Cajun Tach Shop also has boards for aftermarket tachs.
I thought mine was original, but it was aftermarket. I had ordered a board for the original, then when it arrived it was way different. I contacted him, and ended up sending the whole tach to him so he could install the board and calibrate it properly. He did a great job. I am very happy with his work. |
08-31-2020, 04:02 PM | #8 |
One of the First
If you guys don't want to run Petronix, I've used these guys for many years:
https://performancedistributors.com/...nition-system/ They use to be made wholly in USA, not sure about products these day. But, never had a problem with a OEM tach with this setup.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
10-20-2020, 02:01 PM | #9 | |
Greg seems very genuine when providing excuses on the phone, but after several months you have to fish or cut bait. I gave up on him and ended up buying a CounterPart tach from Truck/Car Shop. So far it is working fine with my GMPP HEI.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 10-20-2020 at 02:07 PM. |
10-20-2020, 02:28 PM | #10 |
Post Whore
My Burban has a factory tachometer in it and it has always read high at idle by about 300 rpm and 800 or so at 55 mph. Last week I replaced the HEI with a Pertronix set up and the unexpected benefit has been the tachometer reads about 75 rpm low at idle and 300 at 55 mph.
I am guessing the rest of the error is in the 50 year old tach.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
