10-15-2020, 03:00 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Belt drive accessory kit
350 block.
Hope I'm asking the right question here. This is my weakness in the rebuild. It originally had a V belt setup. I wanna stick with that unless a serpentine belt setup is about the same price. PS, AC, water pump, alternator, and all needed brackets. I think that's it. Basically, I'm looking for an idiot Proof kit. Straight bolt-on. Thanks. Last edited by truckdude239; 10-18-2020 at 02:53 PM. |
10-15-2020, 03:45 PM | #2 |
Re: Belt drive accessory kit. WTB
I'm using the serpentine belt system from a 98 Silverado, including the PS pump, alternator, and AC compressor.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-15-2020, 04:38 PM | #3 |
10-15-2020, 06:03 PM | #4 |
Went with the same era serpentine set up. Got it at the pik a part. Make sure that if you go there that you get ALL of the nuts and bolts. Because they are a mixed lot and in some cases hard to find correct replacements. Bolted right up. Remember that you will need to get the appropriate water pump. They turn the opposite direction of the v belt variety. Also got a voltage gauge from Tbone. Because the amp gauge dosen't read right with the new alternator. I am happy with this set up.
Smitty '71 Short Fleetside Spring Valley, Ca. |
10-15-2020, 06:11 PM | #5 |
They fit except early small block heads that have no acc holes in them
88 to 98 trucks have 3 different styles Early stamped steel brackets 90 to 95 and 96 to 98 Need in insure you salvage all the brackets ps pump pullys alt etc. |
10-15-2020, 08:17 PM | #6 |
Sorry, I was working on the Blazer... Yes, just as the others have said. Get everything. Your PS pump has a large fitting on the back - you can remove it and swap it for the one that has the serpentine belt, so you don't have to change hoses or fittings. If you have AC you'll need to decide how to adapt the fittings. I replaced my AC evaporator and condenser with parts from a 98 Silverado. I plan to do a write-up as soon as it's complete.
10-15-2020, 10:21 PM | #7 |
Did the same with mine except mine came off a 1994 5.7 Please heed our advice about the water pump. I didn't realize and had no idea and almost fried my 2.02 heads. Once you get it up and running and as funds become available, you can always swap out the accessories with new ones from O'Rileys. IMHO i would go and get a new water pump right away. Try to remember what the make and model of the vehicle is that you obtain these parts from so you can tell the parts people what the application is. A new clutch for the fan couldn't hurt either.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
10-16-2020, 10:31 AM | #8 |
I was lucky. The registration was in the glove box for the one I took my parts from. Keep it with all the other paperwork for the truck. Getting old and occasionally misplace info in my head.
10-16-2020, 12:50 PM | #9 |
The mid 90's serpentine swap is easy and cost effective. I've done 4 now, 3 junk yard picking and one with a new complete kit from GM. Lots of threads to review and get hints from. Like said above, get all the brackets and fasteners from the same vehicle or same year vehicle. Get all the accessories like the alternator, clutch fan and fan blades, PS pump, water pump, idlers...... May have to pick from several vehicles. Get the year of the doner so you can get replacement parts in the future. There is also an adaptor to go from the original alternator pigtail to the new one. Ask lots of questions, many have made this swap. Good luck, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-16-2020, 01:12 PM | #10 |
Also avoid the bracket with the passenger side air pump, I had to cut a chunk off just above the fuel pump.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
10-17-2020, 10:24 PM | #11 |
Its a Truck Thing......
Here is my write up from way back.
My kit is still on my truck with these parts so I can say it works. Also 4.3's from mid 90's works, just check the alt location. Get the support rods, if you use them you don't need to drill the passenger side head for the upper inner bolt. Make sure you take a puller for the PS pump pulley or you will not be bringing home a good kit without breaking the bracket. http://67-72chevytrucks.com/vboard/s...d.php?t=468729 Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
10-18-2020, 04:25 PM | #12 |
Thanks all. It's a 1975 350 engine. The years mentioned above should still be good?? This will be very cost effective in price savings. Gonna take lots of reading time.
10-18-2020, 06:31 PM | #13 |
I just built another one the other day..... 4.3's are better brackets in my opinion. No smog pump on them, but if your in CA everything might have a smog pump bracket.
Smitty
