Old 10-21-2020, 10:18 AM   #1
Leroy-B1
Rear end help
So I bought a rear end from a local guy and he wasn't sure if it was a 68, 69, or a 70....The problem I have is I want to order the 5 lug conversion axle kit and not sure which one to get.. The brake drums are off and I am measuring from square flange on end of tube to the same on other side and the measurement I am getting is right around 56.25 inches from square flange to square flange...if I measure from backing plate lip to other backing plate lip its right at 55 inches...Can anyone help me? The kits are 63-69 and then 70 only...don't want to order the wrong one. Looked at old threads and didn't get a lot of helpful info that I understood...lol
Thanks in advance.
Leroy-B1 is offline   Reply With Quote
Old 10-21-2020, 10:55 AM   #2
kwmech
Re: Rear end help
Call the people making the kit??
Old 10-21-2020, 11:02 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Rear end help
This is from an older thread.
(Backing plate to backing plate measurements)
If you are still unsure pull an axle and measure.
axle width is 55.5 wide with 30.5 long axles on the narrow rear end. earlier rear end
axle width is 57 wide with 31 5/16 long axles on the wider rear end. later rear end
Keith
Convert to disc brakes.
Old 10-21-2020, 11:06 AM   #4
Leroy-B1
Re: Rear end help
ok...think mine is an newer one...will most likely have to pull an axle if I can find time
Old 10-21-2020, 11:16 AM   #5
Leroy-B1
Re: Rear end help
Trying to save some time by not taking it apart at the moment...I'm a school teacher and in grad school and both my sons play travel baseball, don't have a lot of free time for a couple of weeks to do it and wanted it to be here for when I am free....Its going under a 60 apache I'm changing the suspension on.
