Clear coat on a new master cylinder
I just put a brake master cylinder in my 73 Jimmy. After thoroughly cleaning it, I applied 2 coats of clear coat (like I always do) before bench bleeding it.
It occurred to me, not everybody realizes this is an option. I have been clear coating new master cylinders for ...20 years, maybe? I thoroughly clean the outside of the master cylinder with brake clean, let it dry, and spray it with 2 coats of clear spray paint. It ain't perfect, but it does add some level of rust prevention. I have had master cylinders that were [at least] 5 years old with almost zero rust. Anyways just thought I'd share that tip. Results may vary -Russ
Insert clever text here: |
Re: Clear coat on a new master cylinder
doesn,t the brake fluid eat the clear ?
Moderator
![]() Join Date: Dec 2012
Only if you spill the brake fluid ;-)
I cleared the natural aluminum intake on one of my 350s 25 years ago. Still looks great. |
Clear coated many iron masters even back in the day when I was a tech at a Chev dealer ship. The service manager gave me the tip. If you get some brake fluid on it its easy to clean and touch up. Rusty masters are not pretty.
![]() Join Date: Sep 2014
I clear coated my original 307 valve covers on my first 68 42 years ago and they never had a hint of rust.
Post Whore
![]() ![]() Join Date: May 2015
I used Eastwood master cyl paint on mine..also painted my calipers with it as wel.so far it still looks good..has a raw cast iron look to it..
Never thought about using just clear...
I shot mine with SPI epoxy. Its only had fluid in it for a few months and I don't think I spilled any but it looks great.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
I prefer the "patina" look, lol.
Yeah.... But AZ has that "dry-heat" so it's only 'patina' out on the West Coast LoL.
Use cast blast on iron parts . Summit valve covers are what my builder puts on to dino I've changed them since
