03-01-2021, 06:08 PM | #1 |
Active Member
700R4 Tranny for $150 - Buy or Not?
So I eventually want to upgrade from my 3-speed to an automatic. Found a supposed 1991 700R4 transmission that the seller said needs to be rebuilt. He's asking $150 for the tranny. Is that too good to be true or are these things really expensive to have rebuilt? Maybe I wait and just buy one already rebuilt? What would ya'll do?
03-01-2021, 06:10 PM | #2 |
Re: 700R4 Tranny for $150 - Buy or Not?
$150 US is what they go for where I live, it's not a bad deal. 1991 is a good year to get, too. I assume that it is a 2WD and you have researched these transmissions so you know what you are getting into.
I spent another $1500 US to get it built with shift kit and stall, and I couldn't be happier.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
03-01-2021, 06:21 PM | #3 |
Active Member
Yeah its 2WD. I have been researching a bit on it but just don't have any price information. At the least it would give me a core if I needed one. I have heard good things about having an OD tranny and with a 3.73 rear end I should still be able to lite up the rear tires if I want to!
03-01-2021, 06:37 PM | #4 | |
I drive the highway/freeway about 60 miles a day and I cannot overemphasize what it did not just for RPMs and fuel economy, but for drivability. It lights them up and as a bonus if it is built right the tires break loose when it hits second gear too. Mine does, and my 350 is tired. I'm a bit out of the loop on prices but it sounds like you are paying no more than core price for it. It is possible you could pull one yourself from a junkyard for a little less. Make sure you have the TV cable and bracketry etc included or you might as well do just that. Mine is a 91 as well, they had them figured out by then and they were still non-electronic until 93.
03-01-2021, 07:04 PM | #5 |
Active Member
I can't see a downside to an OD transmission. I'll be bolting it to the little 283 first and then later on, who knows, I might bolt it to a 383 stroker. In any case it'll be a lot more fun to drive. Now I need to locate a column shift steering column and the rest of the parts I'll need. Thank for the input!
03-01-2021, 07:17 PM | #6 |
I paid $173 a few months ago for a '93 700R4 at the local pick-n-pull, and I had to pull it myself without a jack, so $150 sounds like a steal. I'm in the middle of rebuilding it myself right now. I've spent about $500 on parts so far (rebuild kit, sunshell, sprags), and maybe another $150 on tools. I'm doing this mostly for the fun of having a project, and I don't depend on my truck for transportation, so I'm taking my time with it. I installed a 700R4 in a 72 C10 I had a number of years ago, and it made the truck a pleasure to drive on the freeway. I'd say my current truck, with a TH400, 3.73 gears, Flowmasters and side exit pipes, is an intense experience to drive on the freeway. You'll find me putting along in the slow lane doing 55-60.
03-01-2021, 10:31 PM | #7 |
2X on the TV cable, bracket that is bolted onto the intake, fill tube, torque converter cover, electrical plug and yoke from the drive shaft. That is a metric trans so get as many of the bolts as you can. Check to see if the torque converter bolt holes line up to your flywheel. If they need adjusting it is very hard to do with the transmission installed. If you decide to not get it let me know. I've been looking for one. LOL
03-02-2021, 12:56 AM | #8 | |
Get the torque converter also, but just so you can take a look at it: if you're getting it rebuilt don't try to save money by reusing a nasty one with old fluid in it, just get a new one. I got lucky, my driveshaft still fit, but budget for a new one since there are different lengths. Don't worry its money well spent. It seems like a lot of expense and trouble but it was the best upgrade for the dollar I ever did.
03-02-2021, 01:43 AM | #9 |
I've got the original 700r4 that came out of my '91 4x suburban. Every now and then I'll put it on craigs list for 250. It was in good working shape when I took it out to upgrade to a 4l80. Trans, convertor, cable, dipstick tube and gauge and the 4x adapter. It has 125k on it and was starting to whine a little in 1st gear. May need a rear planetary? I would go through it with the mileage on it and freshen it up. Personally I don't like them that's 1 of the reasons I took it out--the other is I plan on doing some heavy towing
03-10-2021, 07:06 PM | #10 |
Active Member
Update: I missed out on the 91 tranny, but ended up finding a 1986 model tranny today. Only $150. Not too bad for a 700R4 that’s going to give me overdrive. Thanks for all the info.
Posted via Mobile Device |
03-10-2021, 08:21 PM | #11 |
Can you return it and get a later model?
03-10-2021, 08:34 PM | #12 |
Active Member
No not returnable. At the least I have a good core to turn in. So what all is wrong with an 86 model? I know the bugs got worked out in the later models.
03-10-2021, 08:48 PM | #13 |
Post Whore
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
