71 air conditioner door help needed
I had a mouse raise he!! inside my heater/AC box. The rubber around the flapper that switches between the heater core side and AC evaporator side is chewed up badly. I would assume that this is called the blend door??? It also doesn't close all of the way. I would assume it is supposed to close tightly so the A/C works as efficiently as possible? Is it fastened in place or is the hinge wire just pressed in? Is this part available from a vendor that anyone knows of? I appreciate any help.
I found the picture below on line while searching for the part. The circled flapper door is the part I am having issues with. Last edited by deadshort52; 03-08-2021 at 11:03 PM. |
Re: 71 air conditioner door needed
rat bastards! Most guys just replace the seal. Fix what you got.
I have searched but can't find the seal available anywhere.
![]() Join Date: Jun 2014
Or post a "wanted" in the parts for sale forum...
RP |
The Older Generation
Members can't post a "want to buy" unless they are a Premium (paying) member. LockDoc
