03-19-2021, 03:05 PM | #1 |
Will 15x8s fit all the way around?
Have a stock 67 c10 setup, drums, nothing changed. Will 15x8s fit the front and back with no issues? I will probably be running 275/60R15 tires all the way around as well. Thanks.
03-19-2021, 03:53 PM | #2 |
Re: Will 15x8s fit all the way around?
Pretty much stock size wheels think you will be fine. Are you lowered?
69 longbed 350 700r4 3.73 POSI cruiser |
03-19-2021, 03:56 PM | #3 |
03-19-2021, 04:15 PM | #4 |
Think you will be fine have you got the tyres already? One thing to think about if you install wide tyres on a run at the front with a high sidewall the tyre rolls on the rim in corners. I made this mistake but on a 7 inch rim on the front. Just something else to think about if you haven't already
03-19-2021, 04:20 PM | #5 |
Recomended tyre sizes for 8 inch rim
Here you go mate straight from good old google
03-19-2021, 04:23 PM | #6 |
Attached
03-19-2021, 04:29 PM | #7 |
275/60R15 is a great size for a 15x8. I run that on the rear of my musclecar. Not sure if it will fit on the front of the C10 though.
03-19-2021, 05:21 PM | #8 |
Im running 275/60/15's up front with 50 year old sagging springs and i have zero clearance issues
350/th350 Sportsman2 heads Performer Intake 1406 carb 3.42 Eaton Posi |
03-19-2021, 06:04 PM | #9 |
15x8 on the front with 2"lowering spindle you will have to trim the lower control arms a bit
03-19-2021, 07:07 PM | #10 |
15x8 all the way around with 255/70-15 tires. Four inch drop in the rear and 2-1/2” drop spindles in the front. No trimming of anything required. A slightly wider tire wouldn’t be an issue that I could see.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
03-19-2021, 07:30 PM | #11 |
I have a '67 K/10 Suburban. It had 15 x 8 rims with 33x12.50x15 tires on it. Tires were fine.
When I tried the 15 x 10 rims [and 33x12.50x15] from my [then grounded] '71 GMC Jimmy, I had turning problems with the front end. Had to switch back.
03-19-2021, 08:29 PM | #12 |
Mine fit just fine. 15x8 275/60 15 on all 4 corners with a 2/4 drop.
03-19-2021, 08:42 PM | #13 |
Proprietor of Dale's Corner
Most will fit fine, but, what's the back spacing on the wheel?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-20-2021, 08:24 PM | #14 |
Thanks for the feedback...think I will go with the 15x8s with 275/60R15 on all 4 corners.
03-21-2021, 08:55 PM | #15 |
Simple answer yes I did in the past. No issues. Preferred 255 in front
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-22-2021, 02:07 PM | #16 |
I have 15" x 8" truck rallies on my '69 GMC. Tire size is 255/70/R15 BF Goodrich Radial TAs. Stock suspension with new springs & shocks. I have no issues with clearance front or rear and lock to lock. I almost wish I had gone wider & taller because there is plenty of room.
03-22-2021, 05:15 PM | #17 |
I must be the odd man out here. My 69 is around 2" lower than stock in the front. Tires are 255-70x15 on 8" rally wheels. I had an issue with the front tires barely rubbing the bolts that attach the inner fenders to the fender lips. (Mostly on fast turns with bumps in the road.) Ended up replacing the top ones with button head bolts. Problem solved. Spindles and rotors are from an 85 C10, so it's possible they stick out a little more than stock.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-22-2021 at 05:22 PM. |
