![]() Join Date: Dec 2013
396 clutch set up question
Replacing the I6 with a 396 (67 Chevelle),and I’m stumped on what clutch rod and z bar to use. Length of rod from pedal to zbar, correct zbar? I bought a kit for a 67 Chevelle but it’s not right. Pedal rod is too short( I6 is too long). I think I need something between the stock I6 and the Chevelle.
Posted via Mobile Device |
Re: 396 clutch set up question
Anyone have a picture of their 396/ clutch linkage at the z rod? Thanks.
I would think you would want truck parts, not Chevelle parts for all the linkage. Dimensions for a truck will be different than a Chevelle or a Corvette. Here is a post that shows the linkage but not really any rod lengths.
http://67-72chevytrucks.com/vboard/s...d.php?t=499589 This site has some linkage photos https://www.4speedconversions.com/68_truck_linkage.html
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Thanks for the reply. I checked that out and found a couple other threads. I might need to fab up a bracket for the side of the block. Always thought the pivot just screwed in the available holes. Apparently not.
Anyone have a picture of the big block engine block bracket? 4 speed conversions says it’s different from the small block, but they don’t have a pic or sell one. I don’t believe it would be hard to make if I had a picture.
I found a picture. Man, the things you can find on here if you have the time!
Now, does anyone on here have one for sale? |
#7 | |
The Older Generation
Since you are a Premium member the thing to do is to post a Want To Buy on the 67-72 truck parts board. The message board isn't supposed to be used to buy and sell parts. Thanks, LockDoc, Moderator
I did. Thanks.
I always search with ‘Google images’.
Usually a few hundred links with pics come up. Like this one I just did. Likely easier to just make one. https://www.google.com/search?q=z+ba...EA&sclient=img |
Cool. Thanks.
If you get one, it would be nice if you could draw a blueprint of it and post it.
If I do, I will. Weird that no ones made some of this stuff.
#13 |
![]() Join Date: Aug 2020
I have a 396 with a NP435 four speed and I can get you pics or measurements if you still need them. My truck is apart right now so the stuff is in boxes.
It's not rust, it's called patina Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust. |
#14 |
Thanks 68 panel. What’s the pivot length of your z-bar ? Do you have the above pictured bracket or use something else?
#15 |
You're welcome. Yes, I am using the bracket that bolts to the engine. I think I read that they are hard to find and quite $$ if you do find one. Just a FYI, I bought this truck almost a year ago and I knew at the time it needed a clutch. When I took the truck apart while restoring it I found that the Z bar was welded up for a repair and the push rod was worn almost to the point of breaking. I got used pieces from Ebay to replace them. One slight difference is the pushrod. The old rod is 19-1/2" center to center and the new one is 20" BUT the old one is bent a little so that may be why. The new (used) pieces in the pics are the painted ones. I am still working on the truck and have not put he linkage back in to make sure everything works
. The Z bar is 6-3/4" long and both arms of the Z bar are 4" from the center of the Z bar to the center of the push rod hole. The original push rod is 19-1/2" long, center to center. The one I am going to use is 20"
#16 |
I made a link to more pic that you may find useful.
https://photos.app.goo.gl/mi4C2QD5bUUSSQDTA
#17 |
Wow! Thanks man. Those definitely help. One more pic, could you put the bracket beside a ruler or tape and also measure the place where it bends, or how much it bends.
#18 |
Your thru the wall pushrod is definitely different. Mines the straight long one in the first photo.I wonder if it’s a 6 cylinder to big block difference or 1968 to 1972 difference. This stuff just isn’t supposed to be this hard! Ha
#19 | |
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#20 |
Will do but it might be a few hours. I'm not home right now.
#21 |
Thanks Grumpy, that clears up a bunch.
Don’t get in a hurry to take the pics, just try to when u can. I’m not at the shop yet today anyway. I appreciate the help. |
#22 |
Ok, I added a few more pics to the album. It's hard to show but the two mounting holes are not on the same plane where they touch the engine. There is only about a 1/8 " difference between the two where they touch the engine. This bracket is not flat, it's more of a twisted shape to conform to the engine. Let me know if you need more pics or measurements.
#23 | |
