07-12-2021, 05:49 PM | #1 |
Air Bag's Help - Please
Hello everyone and I want to go ahead and thank you for the help. I have a small issue, and wouldn't mind some suggestions.
I have a 1965 C10 SWB and it's been on air ride for about 4 years. It currently has cupped arms up front with stock upper and lower control arms. Today while doing maintenance and checking things out after a long driving session over the weekend at SETN, I noticed my front bags are rubbing. It looks like they are rubbing while driving and when I air it out. Currently running Dominator 2600 bags up front and was thinking maybe go with a smaller diameter bag like a Ss5 Bag, but wasn't sure if anyone has used anything else or have used the Ss5 or 6 bag and wanted some suggestions before committing. I appreciate it everyone. |
07-12-2021, 07:26 PM | #2 |
Re: Air Bag's Help - Please
smaller bag will ride way stiffer as it takes more PSI to do the same work.
a bag that is rubbing anything is doomed. it MUST be fixed. post pictures of what is rubbing, and time to get out the hack saw and bubble gum, but it needs to be dealt with asap, or you'll have a hole in the bag. many times, depending on how the bag is mounted, you can rotate the mounts and since they are offset, will give you adequate clearance. but this is all speculation, since there are no pictures.
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
07-12-2021, 09:19 PM | #3 |
67-72 parts collector,…
I’ve heard that the re7 or SS7 bags from Slam Specialties don’t balloon as much as the AirLift Dominator bags.
07-13-2021, 09:18 PM | #4 | |
I didn't take pictures but it looks like the bags might of shifted forward in the brackets maybe from a pot hole or something. I mean I have 4,000 miles on the setup and it's nothing but rough roads around here. So I think just to be safe even if a bags shifts I'm going to go with a smaller bag. Maybe a Ss6, or a Ss5. I'm okay with a rougher ride I have ride tech shocks so I'll adjust along with them! I appreciate the support and reply. |
07-14-2021, 12:14 PM | #5 | |
07-14-2021, 07:30 PM | #6 |
