08-13-2021, 10:04 AM | #1 |
1965 Armrest Hole Question / Need Help
I seem to be having an issue with a 1955-66 deluxe armrest. I purchased a set to install in my 1965 Chevy Suburban and it appears the mounting holes in the armrest are off considerably from my OEM door panel that came with the mounting holes/cage nuts installed from the factory.
I'm fairly certain that I read that all years are the same and I am aware that the 1966 armrest crossed over to the 1967-Mid 1968 body style, based off of that information I checked an OEM template I have from one of my NOS 1967 armrest boxes. The template matches my 1965 door panel perfectly. So I'm not sure why these armrests are so far off? I see plenty of guys run them. Does any one have hole to hole measurements of their "Deluxe" style armrests? Any help would greatly be appreciated!
1968 Chevy C10 Shortbed 2WD - Current Frame Off 1965 Chevy Suburban 2WD - on AirRide 1985 Chevy C10 Shortbed 2WD - OG Paint/Patina |
08-13-2021, 10:20 AM | #2 |
Moderator
Re: 1965 Armrest Hole Question / Need Help
I don't believe mine have the larger end width like yours show. I got mine at the Truck Shop, but Classic Parts https://www.classicparts.com/1955-65...info/19%2D633/has them also. That one doesn't look right you have there.
08-13-2021, 11:09 AM | #3 | |
08-13-2021, 11:17 AM | #4 |
It's Better With Nitro
That looks like a 53-54 Chevy car door armrest.
08-13-2021, 11:24 AM | #5 |
I've reached out to the company I purchased it from, they are looking into it if it was packaged incorrectly. I was starting to think the same, like from a Chevy 210 I thought.
08-13-2021, 01:12 PM | #6 |
That's definitely the wrong part. I purchased a pair of the aftermarket ones and they fit just fine. My doors didn't have armrests on them when new because there's no cage nuts on the inside. I'll have to change that at some point
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-13-2021, 01:25 PM | #7 |
Moderator
Yes, I think your right. - https://www.chevsofthe40s.com/detail...Assembled.html
And - https://www.nationalchevyassoc.com/U110 And - https://www.ecklers.com/chevy-armres...RoCWjkQAvD_BwE
08-13-2021, 01:45 PM | #8 |
Thanks all for the input. Now I'll await the company and see what they can do.
Appreciated, I guess this case is solved!
08-13-2021, 08:03 PM | #9 |
Oddly enough, my mine has two sets of factory arm rest square mounting holes for the cage nuts. One narrow and one wide, or is it one fore and one aft.....hmmmm, I always thought it was the latter but now you got me wondering.
08-13-2021, 08:11 PM | #10 |
Just so happens the panel is off my 64 right now so I too a pic...likely its for fore and aft no?
08-13-2021, 08:45 PM | #11 |
Moderator
But the door panel holes would also have to different. Spacing looks the same though. I think mine also has the same unused holes.
