08-18-2021, 04:44 AM | #1 |
Wiring kits. Alternatives to Painless?
Morning all!
After taking a good look at Woody’s harness I have decided to replace with a new one, the obvious choice being a Painless one. Have looked at the website and must admit I am being tempted by the Pro Series but $500 ish is pushing my budget BUT it does look like VFM. Question is, are there alternatives? Am I being blinded by the lure of Painless ad Dollars? Woody has an LS awaiting instal, will be with a GM computer and a stand alone harness to get him back on the road. Longer term I would like to go with a Holley Terminator but main aim is just to get back on the road. So… what am I missing? Any and all advice welcome. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
08-18-2021, 06:00 AM | #2 |
Moderator
Re: Wiring kits. Alternatives to Painless?
American Autowire seems to be the favorite around here for this series trucks. Is it cheaper? No. But I think it's far more complete for our series trucks - https://www.americanautowire.com/sho...66-chevy-truck
08-18-2021, 04:41 PM | #3 |
I used a generic wiring kit from SpeedwayMotors. Used with the existing firewall plugs and grommets, it was a good install. Time consuming, but good. And the kit is just over $200..
Posted via Mobile Device |
08-18-2021, 05:24 PM | #4 |
It's Better With Nitro
I usually don't scrimp on complete re-wire projects. I kind of take the approach of do-it-once-do-it-right-since-it's-such-a-PITA-to-track-down-issues-later. LOL. I've used American Auto Wire and Ron Francis for past projects. For my C10, I used Ron Francis since I had several non-typical components to consider - Pontiac engine with crank trigger, air suspension, MSD Digital 6, Vintage Air system, high-pressure electric fuel pump with futures for fuel injection at a later date, etc. Ron Francis' harnesses are flexible enough to accommodate custom applications while handling all of the regular stuff, and they have awesome technical support.
08-18-2021, 05:26 PM | #5 |
FWIW, I used the Kwikwire 14 circuit kit for my 51 (Carbed) rebuild, it worked great. Good quality, and good instructions.
I paid $340 about 2 years ago.
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
08-18-2021, 07:09 PM | #6 |
Having installed two American Autowire kits over the years, I recently ordered their #510089 Classic Update kit for my 69.
https://www.americanautowire.com/sho...-1969-72-truck Very nice components, A+ documentation, and top notch tech support! I got mine at Summit Racing because they had it for $575 minus a $25 dollar discount on anything over $500.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
08-19-2021, 12:15 AM | #7 |
I used the painless wiring kit for my 1968 C10. It was complete and took me about two days to do the install. It wasn't the cheapest by any means but it was very easy to install and the directions really helped.
While I'm partial to the Painless kit, but the overall favorite I've noticed does seem to be the American Autowire kits. I know there are some differences between the '68 and the 1960-1966 but they are similar enough. |
08-19-2021, 02:02 AM | #8 |
Post Whore
I bought the american wire harness and I'm pleased with the quality.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-19-2021, 04:08 AM | #9 |
Thank you for the replies Gentlemen, very useful feedback.
I have previously used the Painless kit and the Ron Francis one plus a generic £100/$150 unit, all of which had their positives and negatives. As Vin pointed out, I only really want to do this once - sort of a fit and forget - with enough additional circuits for futures. Will give the tech lines a call for Painless/American/Francis and see who fills me with the most confidence if I am considering spending North of $500. Appreciate the feedback. P.
08-19-2021, 09:35 AM | #10 | |
The wires are GM color coded to make things easier I found the kit to be of good quality, and easy to use. |
08-19-2021, 10:51 AM | #11 | |
On the RF kit, the engine compartment wire bundles run through a hole in the firewall and are individually connected to the fuse panel on terminal strips. A negative there is if you ever want to remove the front fenders and radiator support as a unit, you can't just unplug the harnesses at a firewall connector. Not only that, but the RF kit uses cheesy insulated crimp connectors like you'd find in a hardware store to connect wires to the terminal strips. The RF kit I had was purchased around the year 2000, so things may have changed since then. However, I will say that RF support is very good. The kit I mentioned above was installed by a previous owner in a 55 Chevy car, and it had several issues. I called their support line and and spoke with Ron himself, who sent me an installation guide and other docs based on my fuse panel's serial number. One more thing about the latest AAW kits: They come with their #510476 alternator charging kit that uses 6 gauge wire, a bit of overkill unless you have a 140 amp alternator and lots of extra load, like a killer sound system. Sure beats the heck out of fusible links!
08-19-2021, 04:41 PM | #12 |
i went with american autowire, very good quality , good diagrams, good company
08-19-2021, 05:12 PM | #13 |
Got back from London early so made a few calls to the support desks of AAW and Painless.
Only managed to speak to Bob at AAW but was really impressed with his knowledge and his ability to answer my questions around using the loom with an LS, best bit was the he told me I could order it through Summit, save 10% and still use AAW directly for support. Soooooo.... Looks like. am going to be saving my pennies over the coming months to invest in the AAW wiring kit. Still a big investment at just under $600 but Woody is not going anywhere so feel as if it is a worth the expenditure. Still plenty to do before I get to the wiring stage but glad I asked the question and did a little research. Well done Gentlemen, well done. Onwards! P.
08-19-2021, 05:26 PM | #14 |
Moderator
I wish I had gone that way kind of. In past builds I have used Painless and Ron Francis (in different vehicles of course). Which is why I went the way I did.
I think you will be happier.
08-20-2021, 01:45 PM | #15 |
Paul - might be worth asking DTE, as he's in the UK and seems to know his onions:
https://www.facebook.com/Down-to-Ear...73996116246881
Barney, in the UK 1962 Chevy C20 1974 Ford Econoline 1987 Peugeot 205 GTi 1991 Peugeot 205 GTi |
08-21-2021, 10:22 AM | #16 | |
Tech support is fantastic at AAW…. This is a photo of a Hwy 22 mounted on the back of the cab…no holes drilled in cab Last edited by MT65; 08-24-2021 at 11:14 PM. Reason: Add photos |
08-21-2021, 04:01 PM | #17 |
Used a speedway motors kit, no issues with install.
Everything labeled like it should be, it is a 22 circuit universal kit, wish I had gotten a 12 circuit kit instead is my only regret. So far everything I have hooked to it works like it should.
1964 C10 Resto-mod 5.3L - L59 |
08-21-2021, 06:25 PM | #18 |
1965 Chevy C10, 2005 4.8L/4l60
Great tutorial for the AAW harness for our trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=762688
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-30-2021, 04:10 PM | #19 |
A few things about universal/generic harnesses:
I installed an AAW "Power Plus" 20 universal harness in an 82 C10 back when it cost around $250. It was a nice kit and the installation turned out well, but I probably spent at least 10 hours just coming up with plans for fuse panel mounting, and instrument panel and washer/wiper connections. Thank goodness Ron Francis sells an instrument panel connector and terminals, because mine were in bad shape. Also, the rear lighting wires were not long enough even on a short bed truck. On the plus side, the kit wires used GM color codes and it came with GM turn signal and headlight connectors. But I would never use a universal kit again, at least not on a truck with a factory instrument panel and factory washer/wiper as complex as the ones on 73-87 trucks. Probably would be easier to install on a 67-72, but I'd spend the extra $270 or so for the Classic Update kit.
