Old 11-03-2021, 08:07 PM   #1
65C10ED
65C10ED's Avatar
Speedo Gear
After installing a Turbo 350 trans in my '65 C10 my speedometer displays a speed of about 10-15mph more than I am actually traveling. I purchased a set of several different driven gears but was wondering if anyone knows which one would be my best bet for correcting the speedo. My truck has a 373 rear end and 29" rear tires. I can probably figure it out with trying each one but thought it might be quicker with some prior knowledge.
65C10ED is offline   Reply With Quote
Old 11-04-2021, 10:19 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Speedo Gear
Do you know what the teeth are in the transmission? You can do a calculation on the TCI website - https://www.tciauto.com/speedometer-gear-calculator#350
Or an easy one - https://www.inchcalculator.com/icwid...E1NzA5ODQ3NTU=
There is a vid on how to change the gears - https://youtu.be/S6yGNIzCR04
373, gear, speedometer, turbo350
