11-19-2021, 01:59 PM | #1 |
C20 Spring Removal
Next week I'm doing a disc brake upgrade and although I don't need to, I want to remove the front springs to clean and paint everything. Does anyone know if just releasing the lower ball joint and letting the lower control arm down pivoting on the rear bushings will allow the stock spring to be removed or does the lower control arm have to be removed?
Thanks in advance
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-19-2021, 03:37 PM | #2 |
Re: C20 Spring Removal
Yes. You can disconnect the lower ball joint & let the lower a-arm down to remove the spring. You do not need a spring compressor as the truck springs don't "grow" like a car spring does. Of course you need to disconnect the shock & sway bar.
George |
11-19-2021, 06:16 PM | #3 |
That's how I got mine out. You should put a chain through the spring just to be safe when using that method.
Made in America by Americans |
11-19-2021, 11:10 PM | #4 |
Does anybody have this procedure in pictures?
11-20-2021, 03:03 AM | #5 |
I use my 3.5t floor jack and let it down slow. Re-installing make sure the top of the spring is in the pocket correctly
11-20-2021, 12:13 PM | #6 |
Perfect, Thanks for the confirmation on doing this. I will use a chain thru the spring as safety measure
11-20-2021, 06:11 PM | #7 |
When I swapped out the front coil springs on my 68 C20 I was unable to get the outer end of the control arm to swing out of the pocket in the backer plate for the brake drum after releasing the lower ball joint. I had to remove the lower control arm from the frame side.
I had read many discussions on this and I was left thinking that the newer trucks maybe had a different set up for the backing plate. I did not figure out a year cut off though.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
11-20-2021, 06:16 PM | #8 |
Here is a photo showing the end of the control arm not coming out of the backing plate
11-20-2021, 11:55 PM | #9 |
If I ran into the problem that Northern describes I would Remove the backing plate before the lower control arm.
George |
11-21-2021, 02:08 AM | #10 |
I won't run into that problem as I'm removing the entire spindle and discarding. Now if I could only get the lower ball joint to break loose.
11-21-2021, 03:47 AM | #11 |
Hopefully not the nut. If nut is loose back off a few threads leave lower arm hanging with the jack under it but not touching. Whack the spindle where the ball joint goes into it with a BFH. If the upper is already loose reconnect to do this.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
11-21-2021, 01:42 PM | #12 |
I struggled to get the lower to pop open as well. It takes a pretty big hit with a BFH, so multiple hits.
11-21-2021, 02:08 PM | #13 |
You can use a jack and a ratchet strap (around the top control arm 'CA' down to the jack) to compress the spring. The ratchet strap is to control the reaction. I have two sets of spring compressors here and neither would fit the c20 springs.
If you have to hit the ball joint stud, be mindful of mushrooming the stud because you might not be able to get it through the spindle. There are some pics on my build page but when you loosen the lower balljoint from the spindle, the lower CA will literally hang freely, straight down. Be prepared because between the weight of the lower CA and the spring forcing it down, if you don't retain the CA/spring it will slam down and send the spring off. While you are going to the trouble of cleaning/painting etc, you really should replace the CA bushings.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
11-21-2021, 07:29 PM | #14 | |
I'm no expert, but a floor jack supporting the A arm, and IMO as a novice, secure the spring so it can't come at you. Only takes a few minutes to secure one, chain or something.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-21-2021, 08:05 PM | #15 | |
You could use a pickle fork . Either manuel or one that you could use in a Air hammer
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-23-2021, 12:47 AM | #16 | |
11-23-2021, 01:21 AM | #17 |
I usually have good luck removing the spindle from the ball joints by un-threading the ball joints until the castle nut is flush with the top of ball joint end, hit the spindle in the ball joint area with a big hammer a couple of times and the spindle will separate without the need for a pickle fork
1965 c/10 swb 1969 c/10 lwb |
11-23-2021, 12:34 PM | #18 |
Pickle fork is the only thing that worked. Only took a minute. Struggle with it prior forever. LCA bushings shot on one side replacing both sides
11-23-2021, 01:52 PM | #19 | |
I am hoping it is true, that is, cause I have a C20 and a C10 that need new springs.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
11-23-2021, 04:03 PM | #20 | |
George |
11-23-2021, 06:25 PM | #21 |
Thats what I did. Once the lower ball joint is loose and the nut off, I just lowered the floor Jack. the lower control arm pivoted open and spring basically fell out.
11-23-2021, 07:38 PM | #22 |
You really need the weight of the engine to be able to replace the front springs.
11-23-2021, 08:21 PM | #23 | |
11-24-2021, 12:37 AM | #24 |
Actually not really. I have the truck in the air with jack stands under the frame. Remove the wheels, remove sway bar and shocks place floor jack under the lower control arm. Remove the lower ball joint and lower the jack slowly. the lower control arm will swing down releasing the spring and it basically falls out. I just did this so I know it works.
11-24-2021, 12:42 AM | #25 |
Now I just waiting for parts. I'm replacing lower control arm bushings as one side had a lot of play. Other side good, but replacing while I have everything apart. Hopefully tomorrow I can start putting suspension back together with new spindles, brakes etc. Then I need to work on M/C, proportioning valve, booster and plumbing the hydraulic lines. I have new respect for people that work on suspensions, especially older vehicles.
