Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 01-31-2022, 05:55 PM   #1
Johnl48
7" water pump pulley
Looking for a dual groove water pump pulley 7 1/8" diameter with 5/8" center to center of grooves swp 1970 350
Old 02-02-2022, 02:15 PM   #2
Mr_Rich
Mr_Rich's Avatar
Re: 7" water pump pulley
Short or long water pump? I might have one depending on the wp.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 02-02-2022, 02:42 PM   #3
Johnl48
Short
Old 02-04-2022, 01:25 AM   #4
Mr_Rich
Mr_Rich's Avatar
My wp pulley is a short with one groove. The crank pulley I have has two grooves. That is prob what I was thinking.
1989 K1500 Chev. EC
Old 02-09-2022, 12:30 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Does this water pump pulley look like the correct one?
https://67-72chevytrucks.com/vboard/...d.php?t=829806
Keith
Convert to disc brakes.
Old 02-09-2022, 09:26 AM   #6
Johnl48
Definitely the same diameter. Also need 2 1/8" to center hole pattern for fan bolts and 5/8" center to center of grooves to match crank pulley
I went and bought this one I found, it's only 6 1/2" and I had to make fan holes oblong to fit. Waiting for a shorter belt I ordered to see if it works
Old 02-09-2022, 10:30 AM   #7
lolife99
lolife99's Avatar
So are you no longer looking for a pulley?
Keith
Old 02-09-2022, 11:02 AM   #8
Johnl48
I will let you know shortly when the shorter belt comes in but I'm not optimistic, this is my 4th belt. Pm me the price and info
Old 02-09-2022, 11:06 AM   #9
lolife99
lolife99's Avatar
PM sent
Keith
Old 02-20-2022, 03:00 PM   #10
Mr_Rich
Mr_Rich's Avatar
I did find the water pump pulley I used and is now spare. The part no. is 14103159 and it has two V-grooves, 6 1/4" dia., with 2 1/8" between the fan mounting holes and has a 3/4" hub dia.
1989 K1500 Chev. EC
Old 02-20-2022, 05:25 PM   #11
Johnl48
I found one. Thanks
