05-15-2022, 09:47 AM | #1 |
1970 2wd terrible ride quality
I have converted a 70 4wd to a 2wd using a truck frame with trailing arms and 5 in drop coil springs I used the same shocks that I have always used on trucks with the same drop but they bottomed out so I ordered 5.5 in drop shocks now it seems as though it has no schoks just goes bouncing along. What shocks is everyone using
05-15-2022, 12:33 PM | #2 |
Carpe manana
Re: 1970 2wd terrible ride quality
Moved to general K5 message board for more eyeballs.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
05-15-2022, 05:18 PM | #3 |
I’m using kyb part #344055. Mine is bagged but ride height is probably equal to about a 5” drop. They don’t bottom out and ride quality is good to great.
05-15-2022, 11:09 PM | #4 |
67-72 parts collector,…
Did you add the shock relocators and adjustable panhard bar?
Trim the bump stops or remove them?
05-17-2022, 06:07 AM | #5 |
I did relocate the shock brackets and c notched the frame installed adjustable panhard and extended it to the trailing arm mounting bracket this is what I do to all the trucks I have done and have had great results just not on the blazer
