Old 06-25-2022, 05:25 PM   #1
drillrod
Truck keeps cutting off!
My 72 chevy truck with 350 engine will start and run perfect for about a mile and then cut off just like you switched it off with the key. it wont start back up right then. Go back to it several hours later and it will start right up and go another mile or so. What is wrong? Acts like something is getting hot and has to cool down before it will start again.
drillrod is offline   Reply With Quote
Old 06-25-2022, 05:33 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Truck keeps cutting off!
That's usually a loose connection. Wiggle all the connectors in the ignition circuit when it's running (in your driveway) until you fine the culprit. That includes the harness that runs to the fuse block.
~Steven
Simi Valley, CA
Old 06-25-2022, 06:40 PM   #3
mikeshome
mikeshome's Avatar
Need a little more info. What does it do when it shuts off? Crank but no start or no power at all? If no power check all battery connections and grounds. If it cranks look it carb when moving throttle is there fuel ?
mikeshome is offline   Reply With Quote
Old 06-25-2022, 08:20 PM   #4
72c20customcamper
72c20customcamper's Avatar
HEI ? If so check the coil
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-25-2022, 08:54 PM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
Mine with hei did that exact same thing. Turned out to be a bad module. Switched to the “old” one that was in the glove box. That was 2 years ago. No problems since.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 06-25-2022, 09:36 PM   #6
tjc
tjc's Avatar
if you are running Pertronix and the wrong coil or a resistor wire, it will do the same thing.
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 06-25-2022, 11:00 PM   #7
dagnabbitt
dagnabbitt's Avatar
This gets my vote, and it’s the easiest thing to try first.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-26-2022, 09:46 AM   #8
drillrod
Yes I am running the pertronics ignition. when it does this, the engine will turn over fine but wont start. When you let go of the key it acts like it wants to start but wont.
Old 06-26-2022, 10:04 AM   #9
CC69Rat
CC69Rat's Avatar
As others have said, I would bet it's the module in the distributor. The Mallory Unilite was bad about the same thing, same problem. Ask me how I know.
It may or may not be bad though. It may just be out of adjustment.
https://itstillruns.com/do-test-pert...n-7993715.html
I'd try it before I spent any money on it. Hope this helps.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-26-2022, 10:07 AM   #10
72SB
Your Pertronix module requires a full 12v. If your stock dizzy was a points dizzy then you need to remove, bypass the stock resistance wire and install a copper braided 12 gauge wire.
Pertronix has instructions in their kits how to do this.
If the resistance wire has been bypassed then either the Pertronix module and or coil is bad. Problem usually shows up once motor gets to operating temp. Use heat sink paste under module when replacing. Most auto part stores have it for $2. Not dialectic grease, heat sink paste is what yu want
72SB is offline   Reply With Quote
Old 06-26-2022, 04:31 PM   #11
rockyrivermark
Next time it won’t start throw a timing light on it to verify you don’t have spark. No spark is likely the issue but as simple a test as you can do.
rockyrivermark is offline   Reply With Quote
