Old 08-09-2022, 07:30 PM   #1
CC69Rat
CC69Rat's Avatar
Outboard shock mounts - 6.5"-7" Rear drop
Dad and I are changing my truck over to an outboard rear shock mount. My truck is pretty low, and I wanted to run a rear bar, so the original shock mounts had to move.
I got the idea from the No Limit setup. - do you guys think this will work OK?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 08-10-2022, 08:14 AM   #2
SCOTI
SCOTI's Avatar
Re: Outboard shock mounts - 6.5"-7" Rear drop
Only thing I don't care for is the lower mounting position. On a coil truck utilizing a Panhard bar to keep the axle centered, there is slight side to side movement of the rear end housing. If you mount things as pictured, the lower mount orientation will have some bind.
Not saying it would be an issue but it's possible vs positioning a single shock stud @ the back side that allows the lower shock bushing to pivot vs bind.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-10-2022, 08:24 AM   #3
CC69Rat
CC69Rat's Avatar
You're absolutely right..
Like this you're saying? So that way the rear axle housing has the ability to shift laterally as necessary
Chad
Old 08-10-2022, 11:49 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I like this kit from Tinworks Fabrication.
Great quality built products and fast shipping.
It keeps both shock eyes on the same plane.
Similar to the NoLimit kit.
https://tinworksfabrication.com/prod...tion-brackets/
Keith
Convert to disc brakes.
Old 08-10-2022, 01:25 PM   #5
SCOTI
SCOTI's Avatar
I like it as well but it creates the same issue. If your spending the money to correct shock issues, why would you spend it to fix one issue but create another?
Coil/Bag/truck arm/4-bar set-ups w/o a Watts Link to locate the housing will have side to side shift. While slight, it's still enough to create bind. I don't understand why they don't just re-clock the mounting points so the shock can pivot slightly side to side.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2022, 01:27 PM   #6
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2022, 04:39 PM   #7
LS short box
So could make new lower mount like the top mount and then turn the bottom of the shock 90 degrees? Then it wouldn't bind if the rear end shifted a bit.
LS short box is offline   Reply With Quote
Old 08-10-2022, 07:32 PM   #8
SCOTI
SCOTI's Avatar
A simple shock stud like used on the front upper would work or whatever dbl shear set-up for additional strength as long as the lower end can pivot w/o much bind side to side.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2022, 10:27 AM   #9
HO455
Post Whore
HO455's Avatar
Then the binding would occur as the axle moved up and down over bumps. The photo lolife99 posted shows the axle in the very upmost position of travel. The axle will drop at least 6 inches at a minimum at full droop. This relates to around 20 to 30 degrees of movement. The orientation of the shock mounts have been designed to induce the least amount of bind for that style of shock mounting.
I am assuming that lolife99 is planning on installing an adjustable long track bar and a rear sway bar. Both those items will reduce the amount of bind from the lower shocks mounts as they will actively reduce how much the axle articulates.
In suspension design every component's placement is a compromise between what helps, what hinders, and what is feasible under the design limitations.
RIP Bob Parks.
Old 08-11-2022, 01:02 PM   #10
lolife99
lolife99's Avatar
Those pics are from Tinworks Fabrication’s website.
I always do the long track bar to the passenger side trailing arm and standard shock relocator.
Tinworks Fabrication is a great company that is developing a ton of new products for GM trucks of several generations.
Keith
Old 04-11-2023, 09:11 PM   #11
samert111
samert111's Avatar
Where did you get those upper shock mounts, or did you fab them yourself?
samert111 is offline   Reply With Quote
Old 04-12-2023, 11:48 AM   #12
CC69Rat
CC69Rat's Avatar
The upper mounts are Ridetech. I got them from Summit. I think they were $20 or $25 each. They worked nicely. I'm going to give it a shot this way and just see how it goes. If it's binding in any way I'll rethink it.
Chad
Old 04-12-2023, 12:55 PM   #13
SCOTI
SCOTI's Avatar
I don't think the 'bind' (if any/much) will be an issue for you as long as when it's at the normal/average height w/full weight the set-up is bind free.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-13-2023, 02:38 PM   #14
samert111
samert111's Avatar
Are those a 2 pc mount? Can't seem to find a pic on the Summit site that looks like your photo unless it's a 2 pc mount like the photo below.
Old 04-13-2023, 04:18 PM   #15
starman13
New Member
To me, it seems like lots of shock angle with that Tinworks setup.Not what we want is it?
starman13 is offline   Reply With Quote
Old 04-13-2023, 04:40 PM   #16
SCOTI
SCOTI's Avatar
I thought the same. My assumption/guess w/o measuring it is the location was being dictated by the need for clearance vs. the bed/bed floor support/s location on the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-17-2023, 07:32 PM   #17
samert111
samert111's Avatar
I ended up doing something similar using a set of modified Summit rear shock locating brackets. I only have a 4" drop but my rear shocks were at about a 30
degree angle.
Just have to get everything painted up and pretty yet.
Old 04-18-2023, 01:41 AM   #18
Richard
Kind of do not understand the thinking here. With a panhard bar the lateral (side to side) movement will be minimal. Especially with a longer panhard that is more parallel at ride height. Obviously, not a lot of articulation to worry about with the lowered suspension as suspension travel is limited. The change in shock angle even with standing them up more (as stock) will put more stress on the bushings more than lateral movement ever could. That is the reason GM put both of the shock mount bolts perpendicular to the frame. Put my rear shock mounts that way with 16" of wheel travel with leaf springs which will move side to side much more than a panhard setup. I will be able to bottom one rear wheel and have the other at full droop. Granted my shock eyes are a bit different with pivots in the ends. My case is extreme, I still hope I am getting the information stated correctly.
Richard
Old 04-18-2023, 10:29 AM   #19
SCOTI
SCOTI's Avatar
I challenge the idea that the leafs allow more side shift of a rear-end housing vs. a Panhard bar.
Is it possible? Sure.
Is it a legit/correct statement across the board? Not w/o measuring.
Even w/measuring, the parameters would have to be determined before the info is applicable (stock leaf vs stock T/A; dropped vs dropped).
We know the T/A w/Panhard bar allows slight side shift by design. The shorter the bar, the more the shift. So if one is changing the stock shock location/positioning, it's not a bad idea to be aware. Monitoring for unusual wear & tear @ the shock mount bushings (oil change/maint intervals?) until they feel comfortable things are fine.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-18-2023, 02:42 PM   #20
CC69Rat
CC69Rat's Avatar
I completely agree it is a little questionable how it will function, so I guess we'll see. This truck won't see a lot of daily driving, so I'm not real worried about it to be honest.
I have tubular trailing arms and QA1 rear bar, rear links, double adjustable hiem track bar, 315s etc. I'm not concerned about hauling stuff, pulling a camper etc. This truck will be for AutoX and / or spirited driving. I want it to be a touch more laterally stable than vertical anyway.. forward bite being important too, of course. But I guess we'll see what happens. If it's not what I'm thinking it will be I will bag it or change over to coilovers. It is what it is.. (for now)
Chad
Old 04-18-2023, 04:00 PM   #21
samert111
samert111's Avatar
Took the truck for a ride today to see how the changes affected the ride and handling.
The body roll is much improved with the front sway bar added and I think moving the rear shocks to outside the frame rails and behind the Diff also helps with the body roll.
Before my rear shocks were at around 35 degrees tilted forward with the 4 drop springs. Also, there was significant tire hop during hard acceleration. Now with them vertical to the travel of the rear diff travel there is ZERO tire hop but the ride is also firmer, not too bad for a truck but definitely not as mushy as it was.
Old 04-18-2023, 04:23 PM   #22
SCOTI
SCOTI's Avatar
I would expect the firmer ride w/the change in the working angle of the shocks. I would also expect an improvement w/stability w/them being moved to outside of the rails & closer to the wheel vs. the stock T/A location.
Sounds like you're happy so far.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-18-2023, 05:42 PM   #23
samert111
samert111's Avatar
I definitely am happy with the changes.
Next is to replace the rear trailing arms with some Summit tubular arms. Mine are twisted a bit and have a few holes rusted thru in them.
Old 04-19-2023, 02:40 AM   #24
Richard
I know about shift from a panhard. My front axle with a 4 link and the longest panhard I could fit moves over 2" side to side with 14" of axle travel. I was careful to make panhard and draglink parallel and close in length to eliminate bump steer. Just wanted to point out that I believe (also GM) that the lateral movement is typically less than that on angled shock mounts. Pics in my thread show the change in shock angle of rear shocks on my truck. Almost vertical at full droop. Granted that is almost 16" of axle travel. To me reality is that shock mounting will not make any difference on the lowered vehicle as suspension movement is limited. The way I see leafs, the arch puts more strain on the bushings and will cause more side to side movement than a panhard. Yes a flat leaf may have more control of that motion.
Richard
