08-12-2022, 10:23 AM | #1 |
Painting Springs and Sway Bars
What is the general idea about paint on springs and sway bars. Is a flex additive needed? Are there any rattle can options?
08-12-2022, 10:41 AM | #2 |
Re: Painting Springs and Sway Bars
Cleaned to Bare metal then epoxy primer then base coat no additives same with coil springs and leaf springs no obvious paint falling off in 5 yrs.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
08-12-2022, 12:00 PM | #3 |
Good to know. Thank you for input. I just want to do a rattle can refresh. So sounds like it will hold up to the level I need.
08-12-2022, 12:12 PM | #4 |
No flex agent required, clean prep, and spray.
if bare metal use an etching primer, beforehand. |
08-12-2022, 02:46 PM | #5 |
As long as there are not 10 coats of hard lacquer paint it won't crack/peel.
08-13-2022, 07:32 PM | #6 |
Like my buddy used to say when he was close on material thin to win..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
