08-12-2022, 02:04 PM | #1 |
Ignition switch
Looking for suggestions on an ignition switch for my 68 C-10. The original I have is a little wonky, and after purchasing a non-original, I couldn't get it to work at all when installed. thank you!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-12-2022, 02:42 PM | #2 |
Re: Ignition switch
We need more to go on. Is the replacement switch a new one?
No power whatsoever in ACC, Ignition, or Start? Do battery, (constant power), items work? Headlights, tail lights, brake lights, flashers, etc? |
08-12-2022, 03:42 PM | #3 |
Re: Ignition switch
The original switch works, but occasionally there does not seem to be electrical contact through it. The new one I bought installs into the housing, but will not turn with the key - I'd like to find an original ideally to replace mine - if that helps (with the supplied key) it seems to be junk from the get go..
08-12-2022, 04:31 PM | #4 |
Re: Ignition switch
OK, sorry, you're looking for a different switch. The few that I have bought in the past I always get from my local AutoZone/Checker/O'Reilly, etc.
Not sure if there are any NOS out there or even Delcos. |
08-12-2022, 04:42 PM | #5 |
Re: Ignition switch
Thanks for the help - I'll keep an eye out on the parts forum...
08-12-2022, 05:00 PM | #6 |
Re: Ignition switch
try rockauto, where I got my AC Delco.
08-12-2022, 08:54 PM | #7 |
Post Whore
Re: Ignition switch
It may be the contacts inside are dirty or have been arcing and need polished. The switches aren't too difficult to tear apart and clean up. I have had issues with repops (See link below)
You might send a PM to Classic Bowties here and see if he has a good used one. Mel is local in Portland. Also Ram light truck wrecking had one last winter. https://67-72chevytrucks.com/vboard/...d.php?t=818861 Good luck neighbor!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-15-2022, 04:43 PM | #8 | |
Re: Ignition switch
