03-21-2023, 03:23 PM | #1 |
Ignition key door key
My 72 c10 came without keys.
Are the ignition key and the door key the same? |
03-21-2023, 04:10 PM | #2 |
Re: Ignition key door key
Negative.
Two separate keys. The ignition is a rectangular shaped key, and the door locks are more.....”round” And they are “keyed” differently.
"If it ain't broken, fix it 'till it is!" |
03-21-2023, 04:17 PM | #3 |
What year did the keys become different? (My ‘67 GMC uses one key.)
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
03-21-2023, 04:37 PM | #4 |
Same thing with my '69. It has never had 2 keys. Just the rectangular head version. I always thought they should have had separate keys for ignition and doors.
Jim |
03-21-2023, 04:39 PM | #5 |
Roadtrip!
I know originally the early ones did use the same keys. Not sure if or when they changed to 2 different keys in the 67-72s. Check with lockdoc on the board here, he will probably know.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-21-2023, 04:40 PM | #6 | |
The Older Generation
You would be wrong. All '67 - '72 Chevy and GMC trucks came from the factory with the same key for doors and ignition. If you have a truck with different keys for the doors and ignition then someone has changed one or more of the locks, usually the ignition. '73 was the changeover year for 2 keys.... LockDoc
03-21-2023, 04:45 PM | #7 | |
They should be the same if none of the locks have been replaced. The first thing I would do is to pull the passengers door lock out and see if there is a code number stamped into it. If there is take it to a locksmith and have him cut you a key. If the locks are all original the key will fit the ignition. If you don't have a locksmith close PM me the code number and I will cut you a key and send it to you for 8 bucks. If there is no code number on it, the door lock can still be disassembled and de-coded to cut a key. The destructive methods (drilling, sawzall, etc)would be a last resort for me. Picture shows the location of the code number. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-21-2023 at 04:50 PM. |
03-21-2023, 05:21 PM | #8 |
LockDoc is a treasure of knowledge on this website!!!!!
03-21-2023, 07:10 PM | #9 | |
Good to know. Obviously mine have had the door locks, or ignition changed, over the years.
03-21-2023, 08:28 PM | #10 |
Thanks for the vote of confidence.. ... I think it is only because I am on here a lot and do a lot of reading. Yes, I have built a few trucks, but this site is where I got most of my information too. There have been a LOT of knowledgeable people before me. I just like to try and spread it around.
LockDoc
03-21-2023, 08:37 PM | #11 | |
If you are comfortable carrying two keys there is nothing wrong with that. If you ever decide to convert to one key this is a good solution: https://www.speedwaymotors.com/Class...GM,116526.html Not the cheapest aftermarket set, but it is the best aftermarket set. Made in Mexico, it is the closest to NOS or OEM you can get. LockDoc
03-21-2023, 09:15 PM | #12 |
My next question is weather the lock blank/ plug is standard or normal on the passenger side door?
03-21-2023, 10:08 PM | #13 |
20' Daredevil (Ret)
I'm gonna say no. I have never seen that before, only the same type lock as on the driver's door.
03-21-2023, 10:17 PM | #14 | |
I saw a thread about how a '63 C/10 had a 3-way passenger side door handle -- Lock/Neutral/Unlock -- but in '67 GM changed trucks to be unlockable if you pushed the button down, held the release in and closed to door to lock, like the passenger cars. The button would just pop up again. If a turnip farmer came to town, and left the keys in the ignition, and locked the door, how would he get back in? I call it the Turnip Truck Anti Lockout Feature. What year and type of truck is your photo from?
03-21-2023, 11:47 PM | #15 | |
Here is a picture of an original GM blank door lock cylinder. I removed this one from a C50 truck over at my local salvage yard. It is made just like a keyed door lock cylinder except it has a blank cover. I have only seen one other one and it was on the for sale board on here. LockDoc
03-22-2023, 10:15 AM | #16 |
And BTW…my original keys are octagonal - my copies are rectangular.
03-22-2023, 10:49 AM | #17 | |
Yes, that would be all '67 and early '68 only. The octagon head key blanks are harder to find than the rectangular head blanks. LockDoc
03-22-2023, 11:11 AM | #18 |
Location: Herculaneum MO (20 minutes south of St. Louis
Well I guess none of the keys for the three 67s the wife and I own are original then.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
03-22-2023, 12:34 PM | #19 | |
The one on the left will only fit the 1935 - '66 trucks. (no stamp) The center one is for the 1967 trucks ("A" stamp), and the right one is for the '68 trucks "C" stamp). Some of the early '68 trucks may have used the "A" key blank. I have not tried to verify that though. This information mostly applies to original GM key blanks. LockDoc
03-22-2023, 09:07 PM | #20 |
So, is there a code on the driver's side door lock. Since that's the only door lock I have?
03-22-2023, 09:40 PM | #21 | |
Some door locks have a code number and some don't. You will just have to take it out and see..... I always mention the passengers side because That is the one I always remove first to check. Be sure and spray some penetrating oil on the spring clip inside the door so it will slide off easier. And wear some gloves, it can be a knuckle buster when you remove it. LockDoc
04-04-2023, 08:06 PM | #22 |
not here to argue with the apparent guru of keys and locks, but if the expert says they all came with ONE key and not two, then why do all the aftermarket suppliers say otherwise - one square key for the ignition "code C" and the other for the doors - a round key with "code D"?
My darn near original, unmolested '72 C10 has two keys - no reason to suggest any of the locks/ignition would have been swapped out. I don't have the OEM keys, so I went with Classic Industries and got the OEM looking keys, however the door key does not match the pattern to even fit. the key for the door lacks the longest groove at the top most portion of the key (bottom picture - right side), thus I am not certain which key would actually work. Based on visual comparison of "GM keys" online it seems that "code B" is the correct one for my doors. (LEFT - old working key: RIGHT - new not working key)
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
04-04-2023, 11:05 PM | #23 |
Lock doc is one of many things I like about this site, gives us beginners hope we can pull off a nice build
04-05-2023, 12:25 AM | #24 | |
"All" is a pretty strong word, and "all" of them don't say that. The below suppliers list 67-72 truck sets with one key for all locks and I didn't check half of the ones that came up in my search. Some of the aftermarket suppliers don't know, or could care less what is original or correct for a certain year of truck. The 1973 & up truck lock sets are the ones that use two different keys. None of this applies to autos of the same era as some of them used the two key system. https://www.ebay.com/itm/22399368974...38e41162c50232 https://www.ebay.com/itm/32544782428...94a795345dc308 https://www.lmctruck.com/1967-72-che...ock-sets-color https://aapd.net/lock-kit-67-72-284-chevy-pickup-67-72 https://www.manestruckparts.com/stor...&Category_ID=7 Here is a key chart that lists all of the key blanks used for the '67-'72 GM trucks. https://67-72chevytrucks.com/vboard/...d.php?t=246485 You will notice there are no "B", "D", or "K" key blanks listed for '67-'72 GM trucks. That is because they are the secondary keys used for door locks on '73 up trucks. Your '72 would have came from the factory with all of the locks keyed to the "C" keyway and used the same key for all locks..... If your '72 GM truck uses two different keys then one or more of your locks have been changed at some point in it's life. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-05-2023 at 12:37 AM. |
04-05-2023, 12:51 AM | #25 | |
If Doc says it's so it's so. No pressure Doc Speak of keys, I already misplaced one of two from a set I bought from Doc. I took one to the locksmith just today, and they made two more on GM blanks of which they had in stock, a very pleasant surprise.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-05-2023 at 12:56 AM. |
