04-30-2023, 10:35 PM | #1 |
Help 2 identify - hose/cover
Can oneone help identified the sheath/tube/cover? inside my 72 C10 w/ 350/350 with air, I came across this tube about one foot long, which I first thought was a vacuum hose, but it turns out to be a soft rubber tube as there's a slit for easy inserting a wire or the like. It goes into the firewall via a grommet, just under the passenger side wiper arm. Does anyone have a clue what it is/was, or the intended purpose? thanks
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
04-30-2023, 10:50 PM | #2 |
20' Daredevil (Ret)
Re: Help 2 identify - hose/cover
Only a foot long and slit -- I wonder if someone placed it there to cover (and protect) the vacuum line going to the water valve and (via a tee) to one of the A/C dashpots.
04-30-2023, 11:06 PM | #3 |
ironically, my water value has been removed, making it a manual adjustment in the engine compartment to close off the hot water flow (North Carolina truck until recently). Are you suggesting the "vacuum line" to be a metal tubular line that was covered by this rubber sheath that went thru the firewall at the location shown in the picture?
04-30-2023, 11:15 PM | #4 | |
20' Daredevil (Ret)
04-30-2023, 11:57 PM | #5 |
The Older Generation
If it came out of the grommit on the drivers side I would say it was for the oil pressure line. Some of them had a rubber sheath on them. LockDoc
05-01-2023, 06:55 AM | #6 |
Junior Member
That sure looks like a cut-off piece of old windshield wiper blade.
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" |
