05-15-2023, 07:36 PM | #1 |
Wing vent window whistle turns out to be mirror
I've been chasing down rattles in my truck trying to get it buttoned down. I had a nasty rattle coming from the passenger door. I finally discovered it was the glass in the side tripod mirror. At the right frequency it really rattled bad. I removed the glass and put some adhesive on the back; but I broke the glass on trying to get it installed. So, I bought some LMC stainless tripod mirrors for both sided. Installed, look great, blah blah and fast forward.
I’m driving, with my new mirrors, and it seemed my Wing Vent Window was whistling worse than normal. I did my usual fiddling with it, with the usual no results in the whistle. My vent window rubber is 50 years old! Then I got to thinking… I just replaced that mirror, and I don’t like a coincidence. So I took the mirror off. Whistle gone! Put the mirror back on, whistle back. It’s always whistled a bit worse in a cross wind too(another classic Vent wing Blame). Been blaming the wing vent for years. The Mirror whistles, go figure! The good news, I won’t be rassling Vent wing rubber anytime soon. And after 50 years, it seals good and is holding up(knock on wood). I'll go ahead and live the the whistle a few more years now! j
White K20 |
05-16-2023, 08:22 AM | #2 | |
The Older Generation
Re: Wing vent window whistle turns out to be mirror
You're lucky you found it that quick. My wife's DD had a whistle too. I chased it for a while and I finally figured out if I pulled in on the door while it was whistling it would quit. I did the old 2x4 at the bottom of the door and push in on the top a little bit trick and that cured it. I learned 40 years ago that you have to have the window down when you do that or you will have more work to do.... LockDoc
05-16-2023, 12:49 PM | #3 |
Just like everything else, it makes total sense....in hindsight ;-)
Good you got it figgered |
05-17-2023, 07:52 PM | #4 |
Post Whore
Try running your finger around the perimeter of the mirror at speed while it is whistling. You usually can find that one place that is whistling. Then try taping something the size of a sugar cube on that spot and test to see if it cures the whistling.
It may take some experimenting but once you find the right shape then you can make something unobtrusive to attach permanently to cure the whistling. Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-18-2023, 02:49 PM | #5 | |
I'll give it a try, thanks for the tip! j
White K20 |
05-18-2023, 08:55 PM | #6 |
That's real interesting.
