Old 05-15-2023, 08:22 PM   #1
Bunky
Question Lug nut Size ?
A while back I picked up a set of rally wheels off a 4X4. I then purchased caps and conversion lug nuts. After looking at time I believe I have the wrong size lug nuts. I purchased the lug nuts with the 7/8 Hex. These don't appear to fit into my wheels properly...
Should these wheels use the 3/4 Hex or the 7/8 Hex ?
Bunky is offline   Reply With Quote
Old 05-17-2023, 12:08 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lug nut Size ?
That’s the same thing I have used in the past.
The hex size on the conversion lug nut is 7/8 or 22mm.
I had no issue with the taper of the lug nut.
Keith
Convert to disc brakes.
Old 05-17-2023, 12:14 PM   #3
lolife99
lolife99's Avatar
Re: Lug nut Size ?
Both lug nuts should have a 60 degree taper.
Keith
Old 05-17-2023, 09:54 PM   #4
dmjlambert
dmjlambert's Avatar
Re: Lug nut Size ?
What is a conversion lug nut?
dmjlambert is offline   Reply With Quote
Old 05-18-2023, 05:04 AM   #5
Bunky
Re: Lug nut Size ?
It's basically a standard thread lug nut that has the external thread (Dual Thread) to allow for the screw on lug nut caps of the newer vehicle.
4x4, rally wheels
