05-21-2023, 04:34 PM | #1 |
70+ ( Old Skool Club )
Weird Rear End
The pictured 67 GMC is being offered at a local Collector car Auction. Although I said local its 2 1/2 drive from me. This pic is from a video of the truck and noticed the rear wheel is quite a bit more forward that it should be. Has anyone seen this before or know why it's like it is and both sides of the truck are the same.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-21-2023, 04:45 PM | #2 |
Re: Weird Rear End
Bad fitting aftermarket trailing arms... Trailing arm crossmember located wrong.. Something ain't right under there..
05-21-2023, 05:22 PM | #3 |
Re: Weird Rear End
The GMC should have leaf springs. I bet they put the axle where they wouldn't have to modify the driveshaft or something.
05-21-2023, 07:29 PM | #4 |
Re: Weird Rear End
Longhorn bed ??
05-21-2023, 08:06 PM | #5 |
Re: Weird Rear End
Maybe a longhorn bed with the seam filled… that bolt hole in the frame looks to be for the exhaust hanger and looks to be in the correct area with the tire compared to mine.
Doug 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 05-21-2023 at 08:54 PM. Reason: . |
05-21-2023, 08:12 PM | #6 |
Re: Weird Rear End
longhorn bed has the stake pocket center at 8"
05-22-2023, 12:46 AM | #7 |
Re: Weird Rear End
Canadian GMC trucks built in Oshawa had trailing arm suspension as standatrd equipment where the USA GMC built trucks had leaf spring suspension as standard equipment.
05-22-2023, 01:03 AM | #8 |
Re: Weird Rear End
While the axles do set forward in the rear wells as standard, this one seems a bit much. FWIU all Chev and GMC trucks had rear coils as standard. Just happens that it is more common GMC trucks were made/ordered with leafs. There are several threads on this. Easy to see if the leafs were optional they would be listed on SPID. Whether SPID is there or altered is another thing.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-22-2023, 06:21 AM | #9 |
Re: Weird Rear End
I'm stumped.
05-22-2023, 07:21 AM | #10 |
68 C10 Longbed
Re: Weird Rear End
Could that be a Longbed fleetside box on a short bed frame?
05-22-2023, 12:33 PM | #11 |
Re: Weird Rear End
That axle is not right. I think we all agree it needs to be moved back.
05-22-2023, 12:42 PM | #12 |
Re: Weird Rear End
That blue truck is a '67, so the front bottom corner of the bed wheel well isn't rounded the way it was on later years. Here is a side view of another '67. Not having the rounded corner makes the wheel look farther forward.
05-22-2023, 07:47 PM | #13 |
67-72 parts collector,…
Re: Weird Rear End
Looks like a longhorn bed on a 127” wheelbase truck.
05-23-2023, 12:49 PM | #14 |
Re: Weird Rear End
Canadian 1967 GMC 910, yes they had coils in the rear. The red C/10 is correct, rears are not quite centered. But there is something wrong with the blue truck. I'll wager aftermarket parts play into this one.....
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
