Old 07-24-2023, 01:59 PM   #1
697498chevy
Question 1969 C 10 window rattle
Don't see a very current thread about this . Anyone have any weather stripping recommendations ? Is LMC a good source ? Thanks !
697498chevy is offline   Reply With Quote
Old 07-24-2023, 03:54 PM   #2
ESC
Re: 1969 C 10 window rattle
I just bought a set from Truck & Car shop, (think it was Counterpart) brand. All was fine except the insert for the vertical channel was what looked like adhesive backed velcro. So if my window isn't all the way up it rattles due to the play.
ESC is offline   Reply With Quote
Old 07-24-2023, 04:41 PM   #3
697498chevy
Thanks for the good info !
Old 07-24-2023, 07:07 PM   #4
cericd
cericd's Avatar
You also may want to check the door brace that is near the vent window which holds the two halves of the door together at the window opening. It's two tabs that were originally stuck together (welded?) at the factory and if they come loose, the gap where the window felts are will widen and allow the window to rattle even with new felts. In 1972 they added a screw to help keep things solid in that area.
This thread has some great pics and info. https://67-72chevytrucks.com/vboard/...d.php?t=633866
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 07-25-2023, 10:59 AM   #5
697498chevy
Okay , Thanks .
