06-26-2014, 07:52 PM | #1 |
The Older Generation
Pictures of the connector strap inside the door, by the wing vent
A member requested pictures of the connecting strap/brace inside the door by the wing vent window. This is a ’72 door and you can see the screw hole on the interior of the door and the "U" nut on the inside that the screw goes into. The strap is usually broken and this allows the door to spread apart in this area and creates a gap between the vent window and the outside of the door. The screw that was added to the ’72 doors prevented this from happening. You can see that this strap is cracked (3rd pic) even with the screw, but the screw still held it together....The door has to be partially disassembled to repair the strap if it is broken. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-22-2017 at 10:02 AM. |
06-26-2014, 09:06 PM | #2 | |
Re: Pictures of the connector strap inside the door, by the wing vent
06-26-2014, 09:15 PM | #3 | |
You've got trucks growing like weeds in the background! |
06-26-2014, 10:25 PM | #4 |
No problem, Sorry about the delay.
... Please don't tell my wife... LockDoc
02-21-2017, 04:36 PM | #5 |
Thanks for posting Leon! I think I should be able to drill the hole in mine and I should be good to go. Any idea of the size of screw that is used?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-21-2017, 04:46 PM | #6 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-21-2017 at 04:59 PM. |
02-21-2017, 05:04 PM | #7 | |
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
02-21-2017, 10:45 PM | #8 | |
Thanks for posting that up. I know there is a thread on here about it but I couldn't find it. LockDoc
02-21-2017, 11:08 PM | #9 |
Thanks Leon for the great pics. Does anyone have good shots of what it takes to do the "weld" version of the repair?
02-21-2017, 11:30 PM | #10 | |
Here's the thread: 72 Upper Door reinforcement Screws and sleeves
02-22-2017, 09:44 AM | #11 |
It's probably too late since your door is already painted, but I have a 72 passenger door that I could cut that piece out of and send to you if you wanted it "splice" it in. It's not just a hole. It does have some shape to it if I remember correctly. Let me know!
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
02-22-2017, 10:49 AM | #12 |
I noticed on the doors I'm repairing that there is a crack starting. I'll weld it up, but I'm also going to add the screw to each door, thanks for the pics Leon!
The sleeve that comes with WES' screw kit looks like if you drill the hole out just big enough for the sleeve to fit it should look pretty nice.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-22-2017, 10:56 AM | #13 |
That's the piece that I'm preparing to cut out to install one-piece power windows. Does anyone have any suggestions as to how to restore the rigidity of the door without that brace there? I can't convince certain family members to not slam doors, so now I'm a little worried about eliminating it.
02-22-2017, 11:09 AM | #14 | ||
Yes, the ferrule acts as the trim piece and adds strength to the hole to keep the screw from pulling through. Just go easy when tightening it up.... Quote:
LockDoc
04-07-2017, 03:46 PM | #15 |
Leon I have the screws and ferrule kit on it's way. Last question, do you know the diameter of hole that I need to drill? Thanks for all of the help!
04-09-2017, 11:09 AM | #16 | |
LockDoc
04-10-2017, 08:17 AM | #17 |
Anyone have a solution for doors where the screw hole/dimple has been filled/painted?
What about a mechanical solution to the tabs? ie. rivets or a nut/bolt combo - squeeze the skins together, drill hole through tabs, rivet/bolt. thoughts? |
04-10-2017, 08:46 AM | #18 |
04-10-2017, 09:54 AM | #19 | ||
LockDoc
04-10-2017, 10:01 AM | #20 |
I had cracks starting on the edges so I hit the corners and made a "seam" and put a few extra where they connect.
04-10-2017, 10:08 AM | #21 |
Thanks guys. Much appreciated.
12-22-2017, 08:30 PM | #22 |
Great, just what I was looking for. Thank you!
12-22-2017, 08:37 PM | #23 |
Love the pics just looking for more info and visual. Is the kit from WES for 67-71 doors or just the 72?
All of the pre 72 stuff splays out in this area letting water in. |
12-22-2017, 08:47 PM | #24 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI Last edited by Rufas; 12-23-2017 at 12:14 AM. Reason: Add photo |
12-22-2017, 08:51 PM | #25 |
Thank you!
