11-07-2023, 04:44 PM | #1 |
New Member
Who makes new/aftermarket 4x4 frames?
Hey everyone, I’m afraid my ‘72 frame is to far gone in the rear to repair. Other than Roadster Shop or TCI (releasing theirs soon) who makes a aftermarket 4x4 frame? I know there and a few other that make 2wd frames but can’t seem to find any other 4x4 frame builders.
I’m on the east coast in South Carolina and access to good 4x4 frames (that aren’t rusted) is extremely limited. I attached pics of my rear frame and would like to know everyone’s opinion on if it can be fixed. Thanks! |
11-07-2023, 06:39 PM | #2 |
Re: Who makes new/aftermarket 4x4 frames?
Yikes! I don't know the answer, but I hope you find one.
At $40k (Roadster Shop) I'd be tempted to try to build my own.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-07-2023, 07:16 PM | #3 |
None are available new that I'm aware of. I'm in northern central PA. I have a partially rolling solid 1972 Blazer frame with rear diff, springs, driveshafts, and NP205/TH350 available. This is from AZ. The RH front rail has a slight bend, so it will need to be checked for straightness.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-10-2023, 05:57 PM | #4 |
That frame is too far gone. I can't help but wonder what the rest of the truck is like if the frame is that bad.
11-10-2023, 09:21 PM | #5 |
New Member
11-11-2023, 07:35 AM | #6 |
I have a 2wd 64 Suburban frame, 127" wheel base from California. If you decide to put Street Rod cab on a regular frame. Clean, painted, Doesn't get any nicer than this.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 11-11-2023 at 07:46 AM. |
11-14-2023, 02:31 AM | #7 |
Mark over at Motorcityk5 is coming out with a 4x4 frame
Some progress is better then no progress |
11-14-2023, 11:49 AM | #8 | |
New Member
Thanks, I have talked to Mark before about fuel lines for my LS swap and other items. I'll reach out to him after I have confirmed with my restoration shop that is media blasting the frame next week. Hopefully Mark's frame will be a little better price point since it looks like his frame is pretty close to factory setup. Did he give out any info on price point of what all comes with it? Would be nice to have a frame only option for people not wanting to have over 100k invested into their blazer. Roadster Shop's Legend series frame is 30k starting and is meant for LT1 & LT4 engine and has IFS along with a ton of other expensive items added to it. I know its a incredible setup but anyone using their chassis is pushing 150-200k+ on their build/restoration. TCI's chassis is gonna be around 32K w/solid front axle, 4-link front and rear, D44 front & D60 rear, disk brakes both axles, 12" of travel, king shocks w/resi and will have use Atlas transfer case. They will do SBC, BBC, LS and LT engine mounts, choice of gearing for axles (can't confirm but they offer that on their 2wd's) and they are willing to do some changes beyond what they have listed as options. Special Blend Motor Garage's K5 chassis is 60k but all you have to do is put the body on the frame. Its comes with 525hp ls3, 6l80E, fully dressed holley acc drive and vintage coil covers, gm factory height suspension (IFS), disc brakes, hydroboost and master cylinder, full stainless AN brake lines, Full new engine & trans wire harness, New American autowire harness installed and fuel system- fuel cell, pump & regulator (AN or hardline). They have a ton of additional options to, all the way up to a K20 HD Duramax-Allison powertrain w/ 2500HD chassis (25k). Last edited by Piratenation; 11-14-2023 at 07:56 PM. |
11-14-2023, 10:27 PM | #9 | |
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
11-16-2023, 09:14 AM | #10 |
$20K???
For that price I could get a CNC plasma table and make my own. People are getting greedy. |
11-17-2023, 10:31 PM | #11 |
$20k for a bare frame. $20k for a bare body shell. No wonder these things are regularly getting over $100k at the big auction houses. At those prices, one could have over $100k just in parts, not including the labor and materials to build it!
11-18-2023, 11:14 AM | #12 |
And at the end you end up with a fake Blazer just like most Broncos.
11-19-2023, 11:28 PM | #13 |
20k seems steep but I guess atleast there are options if you have no other choice. I wonder if you could use a tci 2wd frame (or other brand) and get some conversion parts. I have seen a couple of companies sell parts to convert the frame in the past. Just can’t remember who.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
11-20-2023, 12:12 PM | #14 | |
It's no wonder people just do VIN swaps. |
11-20-2023, 08:33 PM | #15 | |
11-21-2023, 06:35 PM | #16 |
I really looked over the frames Mark at motor City K5 had at the show. They're very nicely made and fully boxed so they're much stouter than the originals. Seems like he said it was an additional 2,300 with all the lines
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
11-21-2023, 10:50 PM | #17 |
I assume that’s brake and fuel lines? That’s pretty expensive if that’s the case. I re ran all my brake lines a few years ago and it was much cheaper.
11-22-2023, 12:10 AM | #18 |
I would guess so. It was beautiful work though
11-26-2023, 09:52 PM | #19 |
2WD Jimmy
In 1970 You could buy a brand new well equipped Blazer for under $5000.
It's not 1970 anymore.*♂️ |
