Old 11-28-2023, 01:43 PM   #1
1774btcrew
1774btcrew's Avatar
Where to buy the correct valve stems for Alcoa dually wheels
I had new tires put on my Alcoas back in June at discount tire with new valve stems. These really aren't the right size and if I bump them when I'm washing the truck it they seem to start leaking. I asked discount tire if they carry the correct ones and they don't. I need the metal bolt in style with the angled ones for the rear wheels. Also if I knew the actual hole size I could do some research myself. I don't have that option on my wheels as they're currently on my truck. I don't want to ruin $1,700 worth of tires Even if I do have a road or hazard warranty. I really should have saved the old valve stems and just got new seals but I didn't know this was going to be an issue
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 12-01-2023, 12:16 AM   #2
farmall
farmall's Avatar
Re: Where to buy the correct valve stems for Alcoa dually wheels
I had new BFG ATs put on my old Vectors at Discount and asked them for metal stems. They said they did not carry them???
I will bring my own next time.
Valve stems for autos have been .453" or .625" forever.
When I was a tire buster in the 70s only ford trucks had the big hole.
Many metal stems come with both size gaskets.
I have a set of Alcoas in the garage with stems in them still. I think they were off a GMC front drive motorhome. I will try to get a measurement this weekend.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 12-02-2023, 01:29 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I can't help with the size but you might check the Milton web site and see if you can come up with anything.
https://miltonindustries.com/collect...re-tire-valves
That's where I had to get my oval valve stems. for my rear dual wheels.
You might try calling them also.
Be sure and report back to the thread if you would, when you find what you need.
LockDoc
Leon
Old 12-02-2023, 03:36 PM   #4
farmall
farmall's Avatar
Mine are Dill TR543
METRIC CLAMP-IN VALVES
Compatible with aluminum wheel designs with .389 valve hole. Produced with Viton grommets, all KEX Tire Repair clamp-in valves are equipped with high temperature valve cores.
• Viton grommets offer a greater temperature range, a better seal, and a longer service life.
• Easier installation than other Metric valve designs
TR-543 Clamp-In Valve
TR#: TR543
Hamaton: 1-502
Dill: VS-543
Haltec: TV-543
Myers: 24252
Specification
Description
Valve Size mm 60
Box/Qty 100
Your results may vary.
Old 12-04-2023, 11:10 AM   #5
1774btcrew
1774btcrew's Avatar
Thanks to everyone for the input. I will get to looking.
Old 12-04-2023, 03:54 PM   #6
bnorth
Go to a tire shop that does medium truck tires. I believe it's TR545E but I cannot for the life of me remember for sure. You need to be able to get to your rear inners through the hole in your outers.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 12-06-2023, 12:52 PM   #7
1774btcrew
1774btcrew's Avatar
Originally Posted by farmall View Post
Mine are Dill TR543
TR#: TR543
Hamaton: 1-502
Dill: VS-543
Haltec: TV-543
Myers: 24252
Specification
Description
Valve Size mm 60
Box/Qty 100
It looks like those should work for the front. I need to find long rears no for the inner wheels. They offer some for the Dodge Sprinter but they say they are for steel wheels.
Old 12-08-2023, 10:28 PM   #8
farmall
farmall's Avatar
https://www.dillvalves.com/product_c...lamp-in-valve/
These all have the stem hole I have.
https://www.dillvalves.com/product_c...tire-valves-2/
