Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-30-2024, 04:19 PM   #1
HO455
Post Whore
HO455's Avatar
Stink Ten Two. The second Blazer.
I picked up this 1988 Blazer a couple weeks ago it's pretty solid but has some issues to be corrected. Obviously it's an ex-Forest Service rig. Its an odd combination of options 2.8 V6 with a manual transmission, manual steering, manual windows, no AC but a rear window defroster. I'm not sure if the side mirrors are factory or aftermarket as I don't remember ever seeing any like them before.
The first thing to fix is the steering as it has a ton of slop in it. I ordered a Red Head box for it. Apparently most of the manual steering boxes on S10's are S10 only and such the core charge is more than the box was.
After removing the guard on the coupling I found the cause of most of the play.
RIP Bob Parks.
Old 01-31-2024, 12:46 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Stink Ten Two. The second Blazer.
Wow, I really like that, great truck. Post more pics if you can!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-31-2024, 08:46 AM   #3
I love ex-municipal trucks. Even cooler with custom touches. I believe those mirrors are aftermarket. I'm wanting to buy something more trim for the Sonoma. It seems manual boxes wear sooner than power. I think it's that the P/S systems absorb more "road steer" between the box and steering wheel. But I do see the contributing culprit
Old 01-31-2024, 11:20 AM   #4
4793
4793's Avatar
always good to see another Forest Service green vehicle out there, and your Blazer is nice and straight
I think the Forest Service tried to keep their trucks fairly bare bones with options suitable to where the truck was working. I imagine in the northwest rear defrost is more necessary than AC. My Forest Service truck came out of the southwest and is very basic but it does have AC- and, weirdly enough, the cassette deck radio
4793 is offline   Reply With Quote
Old 01-31-2024, 01:41 PM   #5
HO455
Post Whore
HO455's Avatar
Apparently somehow I didn't save all of the post. Here's the other photos. And coupe more. The seats are 95 Camaro and the door panels have had the fabric replaced with GM pleather.
The rag joint was not made of the normal rubber fiber I'm used to seeing (Like the new one) but was made of a urethane looking material. It looked as one part had been broken for awhile as the edges looked kind of polished Needless to say it drives much better now.
I did contemplate converting to power steering but that would turn a 4 hour job to a 4 week job and I'd miss out on all the aerobic exercise.
RIP Bob Parks.
Old 02-03-2024, 09:49 PM   #6
yeah, stick with the Armstrong steering
Old 02-08-2024, 06:52 PM   #7
HO455
Post Whore
HO455's Avatar
The lil Blazer needed a change of tread so out with the Michelin Maypops and in with some Firestone Indy 500s. While up on the lift I got some photos to post.
Front suspension has 2002 spindles and lower control arms with UMI upper control arms.
The rear axle is also 2002 vintage with 3.42 gears bolted to a posi carrier.
RIP Bob Parks.
Old 02-24-2024, 01:07 AM   #8
HO455
Post Whore
HO455's Avatar
I put the new Blazer to work today. Drove out to Orchards and picked up the lower end of new the engine for my 72 Firebird. I was thinking of starting a thread about it in the Alternative Tinkering section once I start doing more than gathering parts.
RIP Bob Parks.
Old 03-06-2024, 11:45 PM   #9
HO455
Post Whore
HO455's Avatar
Got all the wagons together for a photo.
RIP Bob Parks.
Old 05-17-2024, 08:27 AM   #10
HO455
Post Whore
HO455's Avatar
I got to wondering how a Forest Service vehicle was ordered so I took a photo of the RPO codes in the glove box, found a decoder sheet on the interweb and started decoding the 62 RPO's listed.
I was able to decode all but 11 of them. I was surprised as to how many changes had been made to the truck since the factory. The SPID showed it originally was a 4.3 automatic 3 speed with OD and a roof rack. After reviewing I the list closer I started to question the decoder list I was using. Maybe it was for a different year or brand of GM vehicles. Then I got smart and compared the VIN number on the SPID to the one on the truck and found they don't match!
I guess someone swapped glove boxes or dash boards at some point.
Oh well it kept me amused for an hour.
RIP Bob Parks.
Old 05-19-2024, 07:22 PM   #11
HO455
Post Whore
HO455's Avatar
Having driven the new Blazer for a couple hundred miles now I've identified some things that need correcting.
The console has been covered with vinyl to match the seats and door panels. There is a chrome trim piece around the shifter that I don't believe is factory. However the console isn't bolted down and when it is centered on the shifter you can't lay the rear seat flat as the top of the seat hits the console preventing the seat from laying flat. (Photo #1) And if you move the console forward so it clears the seat back the chrome trim then prevents the shifter from going into the even numbered gears. (Photos #3) Grrr!
This will take some figuring out my part to find a clean solution. After close to 20 years of always having the seat folded flat in the old Blazer I'm not going to start going around with the seat up now.
The truck also has quite a few rattles to trace and fix and the drivers side door takes too much effort to shut. And I need to locate a spare tire. One of those space saver spares that is
Then when I when to change oil, the filter I got for the 2.8 V6 didn't fit. Another PO inflicted problem?
RIP Bob Parks.
