C20 to C10 conversion question, wanting confirmation
I have a 67 C20, and I just bought 70 lower control arms. I will be converting from drum to disc in the process, and converting from manual to power brakes as well. The way I understand is this:
Use a standard or dropped spindle from a 73-87 C10 w/1.25" rotor Use upper and lower ball joints from 73-87 C10 Use brake hose for 73-87 C10 Use an outer tie rod as an inner tie rod from my 67 C20. Use an outer tie rod as an outer for a 73-87 C10 Use POL HPAS6570 tie rod adapter to mate the two different tie rods. So do I understand this correctly? Or is there a tie rod combo that doesn't need the special POL adapter? And what about the hard brake lines? Are they the same size, or do I need to buy new ones? |
![]() ![]() Join Date: Jul 2002
Re: C20 to C10 conversion question, wanting confirmation
Instead of using the adapter for tie rod ends, I used the cross link bar from the 86 donor truck. That way everything for parts wee from same truck. If you are cahnging to power steering you'll need to do pitman arm also.
![]() Join Date: Jun 2005
If you are using 70 LCAs you will need lower ball joints for a 70. 73-87 ball joints are different.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#5 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
The upper and lower need to match the year of spindle he is using. The 73-87 c10 balljoints will work in his 67 c20 upper control arm and his 70 c10 lower control arm. His plan is spot on. The only additional thing to address is the fact the 67 frame doesn’t have a indent in it for a power steering box. They make spacers for this issue.
Keith, thank you for correcting me. I thought 73-87 ball joints were larger than 67-72.
#7 | |
The only difference is the diameter of the hole on the c20/c30 lower control arms. They are bigger. The tapers of the balljoints are different through the years. Divided by these years: 60-62 63-70 71-72 73-87
#8 | |
![]() Join Date: Jul 2000
Looking at the attached .pdf file, the mid-80s Pitman arm is different than the 67-72 C10, but idler arms are the same. A while back, someone on this forum pointed out an error or two in my table, but I think I corrected the problems.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Just us the whole front crossmember for the 1/2 ton, unbolts ,like 16 bolts , bolts right into the 3/4 ton frame , I’ve done it ,gives u everything u want
Its a Truck Thing......
Idler Arm is not the same all the way to 87. GM Changed the center link (have no idea why) in 1983 on the 1/2 ton. K6247 +/-T is from 83 to 87. K6096 is from 82 and down.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
think it just went to metric thread, was the change. But cannot remember as all my squares were 82 up.
Thanks for the corrections to my table. I'll do some further investigation.
Speaking of metric, an 82 C10 I used to own was a crazy combination of SAE and metric. Small screws had 7mm hex heads, and some under-hood body bolts were 8mm with 12mm or 13mm hex heads. But I don't remember if suspension and steering hardware was metric or SAE. I guess GM was just dipping their toes into the metric pond, while driving mechanics nuts! Maybe Keith will jump in here.
#13 | |
Stud taper on the link side is way smaller in diameter than previous years. Smitty
#14 |
Thanks guys, just as I thought. Use adapter or change the center link.
But what about the hard brake line for the front? Does it change size from drum to disc? |
#15 |
![]() Join Date: Nov 2018
My set up was from an 86 Cab-n-Chassis and the center link was about 1" too long or short (can't recall) so I used my original 70 and everything on the center link fit with no problem.
#16 | |
Drum lines are larger than the disk lines for the front application. Smitty
#17 | |
Smitty
