73-87 chevy stepside lowered pics
I have recently gotten a 84 chevy stepside 2wd and want to lower it i was thinking about flopping the axle over the spring in the rear and cutting the front springs, I would like some pics and if you could tell me how, and how much of a drop you did thatd be greatly appreciated thanks,
Re: 73-87 chevy stepside lowered pics
i flipped the rear and cut 1 1/2 coils off. at stock hight the gap from the front wheel well to tire was about 4" and the rear about 7". after the flip and cutting 1 1/2 coils the front is not about a 1/2" gap and the rear tucks about 1/2". the hardest part was freeing up the rusted bolts. as far as ride quality goes, its not bad. the raer has 5 leafs and the overload so its fairly stiff and the front as a little softer then the rear.
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Cut coils in the front; relocated spring hangers and removed springs in the rear.
Probably 4" drop in front; approx 5 or 6" in rear. K ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
thanks cory, do u ever have anny troubles with the axle hitting the rubber stoppers? i was told if i did this and didnt c the frame it would bottom out
i want to do the same to my 74 fleetside. did u change the shocks too?
With 20`s...
Wih 17`s Billet Speciealties... Lowered 6/8. |
Ringger, i was wondering if i have to notch the frame kuz i was told i had to or else it would bottom out but i really dont have the money for it
Posted via Mobile Device |
#8 | |
Are you not wanting to notch the frame nate? Youll want to get drop shocks if you flip your axle, givin you have the extra coin.
just cut your rear bump stops off
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
my bump stops were all ready removed. i still have a good distance between my axle and frame, i bottem out my shocks before i get anywhere close to the frame
Good no need for a C notch then...just purchase some drop shocks and you are A OK.
Flipped in the back with a djm kit, 2.5" spindles and 2" springs up front. If i had to do it again, i would only have used 1" drop springs up front because I don't like slowing down for speed bumps and with my current balloon tires I bang my inner fenders on occaision...I also don't like the rake...i'd prefer it level
Chisel off those gnarly bumpstops in the back, put one of those little mushroom tips on, and you've got 3 inch + clearance..you won't bottom unless you are way overloaded. I had to use the shortest shocks summit racing has up front, and my kit had drop brackets for the rear so it uses the stock shocks. |
Nice truck and stance
![]() Posted via Mobile Device |
#15 | |
False Lies
Mine is a flip kit in the rear, with a drop hander kit, and 2.5" drop spindles and 2.5" drop coils. The wheels are 20x8.5 all around.
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
#16 |
Steemin Ehman what is that on the top of your truck Spoiler or 3rd brake light just wondering?
#17 |
My 79, spindles, springs, flip kit, C-notch, & shackles. 15x8's & 15x10's 245/60, & 295/50's |
#18 |
Here's mine 87 stepside>>>Rear is flipped with shackles and relocated front spring hangers (moved up 3") with c notch..I did mine a little different in the front, i have 2' dropped spindles with afco 11'' 1000# springs and adjustable spring cup to insure that it sits level (side to side)18x8 front and 20x10 rears
#19 |
![]() Join Date: Jul 2014
Here's a couple of mine. 3" spindles, 1 coil cut off stock springs, rear flip. Stock steel wheels were 15x7 with 225/75/15. New wheels are 20x8.5 with 5" BS and 245/40/20, & 20x9.5 with 5.22" BS with 275/45/20. No C notch.
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) Last edited by Tilt; 10-09-2014 at 10:56 AM. |
#20 |
I love this thread..
#21 |
#22 |
#23 |
I'm just glad to be here!
Here is one we did:
![]() ![]() Front has 2.5" drop spindles, crossmember raised 1.5" in the frame. PPBFab Lower Forward Arms, Air bags (no air management, only a schrader to set height). 20x8.5 4.5" BS with a 255/40R20 tire. Rear is flipped with the hangers moved up 1" on the frame. 20x10 5.5" BS with a 315/35R20 tire.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#24 |
I like both of those, that red is gorgeous. Here's one I'm workin on. Was gonna leave the body as is but looks like I'm gonna do the paint and body work now
#25 |
This is my 87 Stepside. Not sure of much of its history as I shipped it over from California. It does sit a little lower than others I have seen here. I plan on going lower. Great thread!!
Tags |
73-87 chevy truck, lowered, pics, spring over, stepside |
