Old 01-26-2009, 11:21 PM   #1
sick454
sick454's Avatar
Project "El Cid"
Well, I started!!. Sold the 454 that was in the 72 tuck an bougt a 5.3 Vortec engine from a 2007 Chevy Silverado. Only paid $1,400 for the whole engine, harness, DBW pedal, and cruise control, MAF sensor. ALL the accesories to include, starter, power steering pump, alternator, and A/C Compressor. The engine only has 16,000 miles on it!!! Sweet!!
All I need now is the Motor Mounts, Cross member(I'll make this one), Exahust(modifying the current exhaust) Air filter, Electric fans, and ECU/PCM retuned. If anyone has sugestions or Time saving tips please forward them to me. I have been all over these Forums and have lots of information. but Kowledge s power and applying it is victory!!
Here are some pictures of what I have started!! Enjoy.
This will be dedicated to all Navy Chief Petty Officers, Past, Present and Future!!
Last edited by sick454; 01-29-2009 at 11:43 PM. Reason: Created a name for my project
sick454 is offline   Reply With Quote
Old 01-26-2009, 11:23 PM   #2
sick454
sick454's Avatar
Re: !!!!5.3 Vortec Swap Started!!!!
more
Old 01-26-2009, 11:34 PM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet !!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-26-2009, 11:46 PM   #4
LuckyHenriksen
LuckyHenriksen's Avatar
Sweet man
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 01-26-2009, 11:52 PM   #5
SactoJim
SactoJim's Avatar
Nice......what you doing for a tranny?
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-27-2009, 12:08 AM   #6
sick454
sick454's Avatar
I don't plan on drag racing the truck but I want to do some bolt on performances later(supercharger/turbo's). So, with that in mind I want a tranny that will hold up to Horsepower. Maybe a 4L80-E?? Not sure, any suggestions? Gas milage is the reason for this conversion to begin with. Also the 5.3 Engine is a Flexfuel vehicle.
I will be needing some economical suggestions for headers, fuel tank/pump, tranny cooler, motor mounts, cam, and electric fans. So, If anyone has made this swap and has some suggestions please let me know.
Thanks,
Sick454
Old 07-15-2009, 01:58 PM   #7
jkade
jkade's Avatar
Thanks,
Sick454
A 4L80E is going to kill your gas mileage even with the overdrive. Get a built 4L60E if you want to still get in the 18-20mpg range.
jkade is offline   Reply With Quote
Old 07-16-2009, 08:14 AM   #8
sick454
sick454's Avatar
I did go with the 4L60E transmission, after doing some research i did find the 4L80E does suck on gas mileage, thanks for the info.
Old 01-27-2009, 12:42 AM   #9
LuckyHenriksen
98-02 F Body headers seem to fit these frames well. I picked up a cheap no-name set on ebay for $180 new, and they are stainless
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 01-27-2009, 12:04 PM   #10
oteixeira
If you are leaving the A/C or aftermarket A/C in it's current position, cut the frame pretty much right where it is turned up in front of the passenger mount. Also, you can use the stock manifolds with just a little trimming on the frame as well. I don't have measurements, just take them off, bolt the motor up, and then mark where to cut. I did not try to go cheap on the motor mounts, I want them to last, so I purchased the ECE mounts and they work and look great.
You can kind of see where I cut and how it sits here, I need to do more trimming now that it is sitting in there.
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 01-27-2009, 10:02 PM   #11
sick454
sick454's Avatar
Orlando
Thanks, Orlando. I plan to swap the exhaust manifolds for a set of headers and since the engine is out I want to replace the cam. Has anyone used the ECE mounts with headers(and what kind of headers)??
Shane
Old 02-02-2009, 09:00 AM   #12
sick454
sick454's Avatar
Well, The weather this weekend was beautifull. So, I went for a bike ride! Instead of working on the build. I will be posting what I have gotten don't later next weekend. Sorry for not upadating you folks.
Old 04-06-2009, 01:00 PM   #13
vortec67c10
vortec67c10's Avatar
I pulled a 5.3 from an 02 tahoe and later realized that headers would stick way to far out. I wasnt comfortable with trimming the frame that much. Id say i had to cut a good 3/4 of an inch in a half moon pattern with the stock manifolds. I dont know if we could raise the motor or what but im def looking for a way to stick thoughs things in there. what computer are you gonna use? i ended up using a great one from redline. I also went with a solid 700R4. I was told by many that wouldnt work but it works perfect and way more fun than the 5 speed i had.
5.3 Vortec
Redline stand alone
700R4
B&M on the floor
Lots of rumble
vortec67c10 is offline   Reply With Quote
Old 05-17-2009, 10:48 PM   #14
nuke1
nuke1's Avatar
lookin nnice, i know all about the bike or work thing, but i normally work all day from 7 - 10 then go riding for 2 houtr at nite, my favorite time to ride, i do not sleep much, but i get the best of both worls to an extent
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 07-13-2009, 02:24 PM   #15
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Any new updates?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-13-2009, 08:26 PM   #16
sick454
sick454's Avatar
Yes.... Actually the Homeowners Association for which i live in (I'm renting by the way). Has pitched a fit that my truck is an inoperable vehicle. Even thought there rules state the vehicle has to be tagged and insured, which it is. Co(K suckers!!!! anyway had to move it into the garage. So, Now i make sure I get up really early on Saturday nd Sunday mornings to get out and grind and hammer and weld and make as much noise as i can, so that everyone on my block knows that it won't be inoperative for long!!!!!!!!!!!!!!
As for what has been done.
1.) motor mounts are solid and complete.
2.) Trans mount is solid and complete.
3.) frame has been notched out and painted in the area that were cut to make room for the stock exhaust manifolds and A/C compressor.
4.) researching parts for trans cooler, p/s hoses, fuel pump and possibly new tank, Electric Fans. Any help with part numbers and manufaturs in these areas would be appreciated.
I would like to keep the blazer tank that i have relocated to the rear frame if possible. just need to figure out the fuel delivery / return / pick-up. HELP !!
I'm not looking for pretty here, just effective and reliable.
Thanks,
Sick454
Old 07-15-2009, 01:26 PM   #17
Shon
Thanks,
Sick454
Does your fuel rails have the fuel pressure regulator on there or not? this determines some of the options.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-16-2009, 08:12 AM   #18
sick454
sick454's Avatar
I do NOT have any fuel pressure regulators on the engine.
Old 07-16-2009, 08:20 AM   #19
Shon
Then you will need the vette filter/reg set up.
Old 07-15-2009, 02:05 PM   #20
jkade
jkade's Avatar
Thanks,
Sick454
You can get a good trans cooler from the local parts store. If I remeber right I took a hose from a new model truck and cut the compression sleeve off and had the parts store put the fitting on a hose for the old steering box. Get a radiator and a set of fans from a 98-01 fbody if you want to go cheap. Get a walbro 255 inline pump and a 97 up corvette filter/regulator and you can use your blazer tank. The corvette filter/regulator is easy to make work.
Old 01-18-2010, 10:27 PM   #21
sick454
sick454's Avatar
So got the filter/reg set up from a 99 vette. Now how do i connect everythig to my fuel system. I have TWO fuel lines running from the tank, up to the engine compartment. One i had connected to the fuel pump running the old 454. The other i never used. not sure what the second line was for. I have had the tank down and it connects to the pick up assembly??? This seems to be the one think I am dreading doing. Not sure why, I'm not sure were to put the pump, cut and splice into my existing lines, remove and replace with different fuel lines. HELP me please.
Old 01-19-2010, 06:30 AM   #22
Shon
The one line that is coming from the tank that is actually going INTO the tank is where you put your pump and then the vette unit. and from the vette unit you will run the return line to your tank and the other one up to the fuel rail.
you want the pump probably as close to the tank as possible, I have mine mounted on the frame rail.
You will want to go to Napa or the like and get some dorman brand hard line that snaps into that vette unit and then I used rubber EFI hose and clamped it on those hard lines using the EFI clamps too.
That other line you say is going to your tank is a vent tube probably. if that is the only vent tube to the tank I would leave it alone but if you have more than one you 'MIGHT' can use it as the return line. I just ran a new line and my tank behind the seat is an emissions tank so it has a nipple on the filler neck I put the return line to.
Old 01-20-2010, 08:37 PM   #23
gus
do you have to replaced the gas tank sending unit for an (inside tank) electric fuel pump?
or you just have to get the vette fuel pressure regulator and an electric fuel pump to run them on your existing fuel lines that run through the frame?
Im starting this weeken the swap, will post pics soon !
gus is offline   Reply With Quote
Old 01-20-2010, 08:40 PM   #24
Shon
I am using the stock tank and sending unit and the stock gauges.
I am using the hard line from the tank and then put the rubber EFI hose on it to the pump and then line to the vette FFPR and then more rubber line to the fuel rail.
I was going to use the lines in the rail but didnt like where it ended and how i would have to route it.
Old 02-19-2010, 08:33 AM   #25
eagleuh1
eagleuh1's Avatar
Any updates ? I'm at about this point myself. I've got my engine(2005 5.3 and 4l60e) sitting in frame. Waiting on reply for headers. Still haven't done the fuel tank yet. Got to get headers, make sure they fit and then cut the drive shaft to fit. Would like to see how yours came out on the gas tank setup. LS1Tech.com has a lot of info on the gas setup as far as the corvette filter reg and fittings in their FAQ section. Good luck with yours. Jim
eagleuh1 is offline   Reply With Quote
