Old 05-29-2014, 09:54 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Making Keys For The ’60 -‘66 Chevy Trucks
This "How To" is for the guys & gals that have a door handle with a lock for their 1960-1966 Chevy truck but no key. It is pretty straight forward but I have had a couple of people ask me how to get a key cut for them. First thing you have to do is remove the handle assembly from your door (if it isn't already out). (picture 1).... To remove the lock cylinder assembly push down on the top spring cup and remove the snap ring. (picture 2) Then slide the spring assembly out making sure to keep the parts in order. (picture 3) If you will notice the spring cups are different on each end of the spring. After you have the spring assembly out slide the lock cylinder and shaft out. You don't have to worry too much about this as it will only go back in one way…. On the cast piece just below the chrome cap you should find a code number stamped. (picture 4) If your local locksmith can't cut you a key from that code number that will fit the lock I can. It should also fit the ignition lock and glove box lock if none of the locks have been changed or replaced. I can't guarantee there will be a code number on every lock, but if there isn't, the chrome cap can be removed and a key made by "reading" the wafers in the cylinder.
If you have questions PM me.....
LockDoc
Leon
Old 05-29-2014, 10:15 PM   #2
Lowl!f3
Lowl!f3's Avatar
Re: Making Keys For The ’60 -‘66 Chevy Trucks
thank you. wish i seen this before the locksmith destroy my ignition switch and still charged me $90
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 09-28-2023, 07:29 PM   #3
ironman3452
ironman3452's Avatar
not much of a locksmith if he destroyed ignition, also door lock is the same as the ignition, at least it was on my 64
ironman3452 is offline   Reply With Quote
Old 05-29-2014, 10:46 PM   #4
Softpatch
Softpatch's Avatar
Lots of good info Thank for that
Soooo.... when you going to show us " How to make a Key".?
Come on
Don't make me beg
i live in an area that does not have a locksmith/shoe repairman or a dry cleaner
or traffic light's
we don't lock our car's or house and when we do the key is
"Under the mat/flower pot or on the visor"
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 05-29-2014, 11:06 PM   #5
LockDoc
LockDoc's Avatar
I think that happens a lot. Most of the newer locksmiths don't have a clue how to work on the older stuff....
Come on
Don't make me beg
or traffic light's
I don't lock my vehicles either. If I go to the local restaurant or grocery store the key usually stays in the ignition.
Making a key is easy. First you buy an $800 Framon key machine that will cut keys by code, then you buy the $200 Code program to convert the code numbers on the locks to the cuts on the key blank, put the key blank in the machine, adjust the settings for the key you will be cutting and turn the switch on....
That is why I mentioned in my first post "If you can't find anyone in your area to cut a key from the code # or by reading the wafers let me know."...
There are probably other people on line that cut keys by code too.
LockDoc
Leon
Old 05-29-2014, 11:17 PM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It is people like you contributing that make this site that much more awesome !!
Thanks !!
I will need this soon.
So what you are offering, is if our local locksmith is an a$$hat, you can help us out ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 05-30-2014, 12:07 AM   #7
LockDoc
LockDoc's Avatar
Thanks !!
Thanks John. Yes, I can cut keys by code, or reading the wafers....
LockDoc
Leon
Old 05-30-2014, 04:09 AM   #8
Woogeroo
Thanks LockDoc, this is golden information.
-W
Woogeroo is offline   Reply With Quote
Old 05-30-2014, 09:40 AM   #9
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Kind of related, but you can have a lock redone to match a key too. My son and I took a lock button out of the drivers side of a junkyard truck, and had our local locksmith pull out the wafers and match them to his key. Put the lock button in the passenger door (upside down though), now we can unlock it from both sides.
Took him 5 minutes, and was like $20.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 05-30-2014, 01:29 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks LockDoc for taking the time to photograph and document the process. These tutorials reach a lot of people that may never respond, but benefit from the information.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-31-2014, 08:45 PM   #11
chad64chevy
chad64chevy's Avatar
I agree!!
chad64chevy is offline   Reply With Quote
Old 06-02-2014, 09:53 AM   #12
MikeN
MikeN's Avatar
I learned how to make keys and re-code lock cylinders while working the parts counter at a Chevy dealership about 20 years ago. It's not too hard. If you find a dealership that still has an oldtimer behind the counter, there's a little hand-held device that will punch out a new key to match the coding of your lock cylinder. Easy to do and not too expensive.
MikeN is offline   Reply With Quote
Old 06-02-2014, 09:36 PM   #13
awbrown
Funny this thread should pop up now.. I had to drive my 63 to work today because the brakes on my 97 were acting up.. Anyways I work in Detroit ,and hate the fact that mine doesn't lock .. I always make sure I have a clear shot from the store to see my truck .... It would sure be nice, then I would have to make my vent windows lock ,..lol
awbrown is offline   Reply With Quote
Old 06-10-2014, 10:13 AM   #14
LockDoc
LockDoc's Avatar
Originally Posted by chad64chevy View Post
I agree!!
Thanks!
I have a couple of the Curtis hand held code cutters. One of them came from a closed dealership auction. You have to have the code book that goes with them too.
I would go ahead and have keys made for the door locks, it would be a deterrent because of the time involved if they had to open the vent window and reach in to open the door....
LockDoc
Leon
Old 06-10-2014, 03:50 PM   #15
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
LMC has a lock for the vent windows. $9.95 a pair...
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=14
Jason
Old 05-30-2014, 01:35 PM   #16
MikeS.
MikeS.'s Avatar
Thanks man.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 05-30-2014, 02:03 PM   #17
Dillon Rock
Very useful. I may look into this in the future.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
Old 05-31-2014, 10:12 AM   #18
LockDoc
LockDoc's Avatar
-W
Thanks -Woog.
I have done quite a few like that. Makes it a lot easier.
No problem, thanks.
Originally Posted by MikeS. View Post
Thanks man.
Glad to be able to do it Mike.
Thanks.
LockDoc
Leon
Old 05-31-2014, 10:36 AM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Does this is in any way give you the ability to IMPROVE these locks? I mean, right now the ol' screwdriver "master key" works pretty good. Wouldn't mind improving that.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-31-2014, 06:59 PM   #20
RANDY COX
RANDY COX's Avatar
That's some good info. I guess I got lucky my Key actually locks the doors and the glove box. I have locked it sometimes since I have a lot of tools in the floor board...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-31-2014, 08:34 PM   #21
LockDoc
LockDoc's Avatar
If the locks are old and worn out, replacing the worn out tumblers and springs with new ones and cutting a new key to factory specifications would restore the locks original security.
Thanks Randy. After that many years a person is lucky if all of the locks match on the truck. Usually something has been changed....
LockDoc
Leon
Old 06-11-2014, 04:33 PM   #22
bhc41051
bhc41051's Avatar
Sometime you're lucky and the key code is on the key.
bhc41051 is offline   Reply With Quote
Old 09-19-2015, 02:43 AM   #23
blackbart63mule
blackbart63mule's Avatar
Thanks for info about the #'s stamped into the lock cylinder. LocDoc, are there different pins or wafers for the door cylinders that are more pick proof? I seem to remember reading in a locksmithing book about it. How hard would it be to key 3 lock cylinders alike for our panels or suburbans? Thx.......Dog
blackbart63mule is offline   Reply With Quote
Old 11-13-2015, 01:12 PM   #24
LockDoc
LockDoc's Avatar
GM has used the Briggs & Stratton side bar lock since 1935 and because of it's design it is almost impossible to pick.
It's pretty easy to key the lock cylinders the same on the '60-'66 GM trucks.
LockDoc
Leon
Old 11-22-2015, 12:00 AM   #25
blackbart63mule
Thanks again for the info Lock Doc!
