06-23-2015, 01:47 AM | #1 |
Project El Viejito, '66 C10 LWB BBW Build
So this is going to be a slow build, but I'm looking forward to documenting this build as I go. There are numerous builds on this site, that help keep me motivated and get me excited to make progress on my project. Here's how the truck looks currently.
06-23-2015, 01:59 AM | #2 |
Re: Project El Viejito, '66 C10 LWB BBW Build
Not sure how the top pic got flipped upside down. I had a rendering done about 12 years ago by Craig Fraser of Kal Koncepts/Air Syndicate in Bakersfield, CA. Here's the rendering:
06-23-2015, 02:03 AM | #3 | |
I am often surprised people do not modify their hoods more. I had a problem between my iPhone and iPad for a while where the photos inverted themselves and even if I edited them and then uploaded, they would still turn upside down on certain forums where I have threads running. Welcome to the board. Look forward to your truck evolving.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
06-23-2015, 02:25 AM | #4 |
Grizz1963, you may be right...some of these pictures are from a digi cam and others from my iPhone. I have to go back and forth between folders, so maybe somewhere in that mix, the iPhone pics got wonky....oh yeah, wonky is a word.
06-23-2015, 02:13 AM | #5 |
First order of business was to pull out the 250 I6/3 Spd.
Then I installed my CPP tubular motor mounts and transmission mount. Now it looks much better...such an improvement. Oh, I can't forget this addition to my project |
06-23-2015, 02:21 AM | #6 |
I'm real thankful for CPP helping me out, they make a great product and it showed up in no time! Next on the to-do-list, is install my CPP c-notches.
06-23-2015, 10:57 AM | #7 |
welcome to the forum. I really like the grill in your rendering. Are you planing to build it.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
06-23-2015, 12:25 PM | #8 | |
Yes, I've always loved the look of the '54 Bel Air tooth grille. Depending on how my luck goes, if I can't find teeth, then I'll see if something similar could be fabricated. |
09-15-2015, 01:24 PM | #9 |
[IMG]H:\My Pictures\My Truck[/IMG]
09-15-2015, 01:28 PM | #10 |
Here's the pic I was trying to post...this was before I cut the retainer off.
09-15-2015, 01:31 PM | #11 |
Also, I came across a guy who had a spare '54 Bel Air grille and offered it to me for free! He said it needed some work, but was mine if I wanted it. I made the hour trip this past weekend and picked it up and it came with 7 teeth including the hard to find center tooth.
I couldn't wait to put it up to the truck to get an idea of the look. |
09-15-2015, 01:23 PM | #12 |
So I'm currently working on installing the c-notches and it's been a big pain...I sheared 3 of the 4 coil spring bolts and stripped the other while trying to remove the coil springs. I got the upper bolts out finally, but still left with the broken bolts thru the trailing arms. I got the pass side ground down flush and tried to drill a hole and use an extractor...wouldn't you know that snapped too.
Anybody have any ideas on how to remove the stubborn bolts?? Last edited by 19SIKtySix; 09-15-2015 at 01:24 PM. Reason: Picture didn't come up |
09-15-2015, 02:15 PM | #13 |
That grill will look great once it has some bodywork done to it
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
09-15-2015, 05:02 PM | #14 | |
I checked out your build, really nice work. Impressive fab skills, your truck is making big progress in a short time! I like your 60-66 that you got. Looking forward to watch your progress. -Chuck |
09-16-2015, 12:29 PM | #15 |
I'm just glad to be here!
Nice Project, can't wait to see more.
Where did you get the C10 Era stickers from? I really like that black and red one...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-16-2015, 06:15 PM | #16 | |
I got the stickers and also a 60-66 T Shirt from www.C10Era.com (hopefully I'm not breaking any rules by posting that, sorry forum admin if I am). |
11-16-2015, 07:14 PM | #17 |
Well it's been awhile since I've done updates, I've been jumping back and forth on a couple little items, I got the notches installed and waiting to get new springs and lowering block before I get it buttoned back up and post pics.
The other thing I've been working on is the one man cab/bed lift by Kevin (Rokcrln). I got the plans from him several months ago, still have a little left to finish but here's the progress pics so far. Nice work on the lift and instructions Kevin, it's been fun building this when I have some time. I'll be working on this some more tonight and post pics when I'm finished
Chuck Instagram: c_lo_garage Check out my 1966 C10 project "El Viejito" here: http://67-72chevytrucks.com/vboard/s...d.php?t=674614 |
11-16-2015, 09:10 PM | #18 |
1961 crewcab
63-64 olds has a nice looking headlight that would work great with that grille.
the housings are separate from the grille and are cast/plated
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-17-2015, 08:06 PM | #19 | |
Thanks for that heads up, I do really like the look of the dual headlight. I had a dual headlight in my rendering, but never knew about the Olds lights. I'll have to keep an eye out for them, see how they would work. By the way, I enjoy looking at your build, killer work!
11-17-2015, 08:17 PM | #20 |
I hope you get that grill sorted out it will look awesome. Looking forward to watching your build.
11-18-2015, 05:05 PM | #21 | |
Thanks, using that grille was one of the first ideas I had when it came to this truck. I've never been a fan of the grilles on these trucks, even though some others love them. I've loved the look of the tooth grilles, especially a Desoto grille on Mercs, such a classy and custom look. I don't think this idea is on that level, but I think that grille will give it some character. Thanks for your motivation, it's going to be a slow process, but I'm going to try to keep progress (even if it is a little progress).
11-19-2015, 06:05 PM | #22 |
So here's my latest update, it's been finished for a few weeks, however there's still a couple parts I need to button it all up and be 100% complete.
The biggest PITA was I broke both lower bolts for the springs, 1 upper and rounded the other upper. I still haven't dealt with getting the bolts out of the trailing arms. Good thing is I was able to locate some arms on CL and they are already powdercoated black. Once I get new springs and lowering block, then the rear will be finished. I took the truck of the jackstands to see how much room the CPP notch allowed, and I was stoked to see 15" wheel tucking. It just inspires me to get this thing bagged and throw a bigger wheel under it. I know there's a long road left to this thing, but the little things give me motivation. Plus, I had never installed a notch before this...it's been fun to get familiar with these trucks and learn some basic skills.
09-25-2018, 09:28 AM | #23 |
That looks pretty cool!
09-25-2018, 04:13 PM | #24 |
Thanks, I wasn't sure how it was going to turn out...but I'm happy with it.
09-25-2018, 09:43 AM | #25 |
1962 C-10
Coming along great! Nothing like having family and friends for help...
The wheels/tires look awesome! Love the "white walls".
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
