#526 |
Re: New 64 Stepper Project
Nice touch.
#527 |
Moderator
![]() ![]() Join Date: Aug 2011
#528 |
![]() ![]() Join Date: Aug 2013
love the striping....
#529 |
Pinstriping
Vince Galatians 6:14 62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086 "If it's too loud, you're too old" ![]() |
#530 |
Moderator
Thanks Joe
![]() Thank you.
#531 |
![]() ![]() ![]() Join Date: Jan 2018
So, when are you going to wash the truck and give us some full beauty shots? These teasers are killing me
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#532 |
Moderator
Post 491 has them.
#533 |
Good point, but I meant with all the pinstriping on it too. Pinstriping or no pinstriping, your truck has turned out great!
#534 |
Moderator
Thank you.
#535 |
Perfect. Absolutely perfect.
The pinstriping really finishes pulling it all together. A long trip indeed, I really enjoy seeing them completed. Lotta hours into this one. Outstanding, Chief!
-JDH Insomnia is a terrible thing to waste https://www.youtube.com/watch?v=jWYVs7widI0 (Misanthropic curmudgeon attempts starting old truck in house at 2AM) |
#536 |
Moderator
Thank you
#537 |
Not bad for a step side
#538 |
Moderator
#539 |
I'm just glad to be here!
Pinstriping is just enough on this truck. I like the one to separate the white and the red. Nice touch!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#540 | |
Moderator
#541 |
Moderator
Drove it into Waco to get a tank of gas, about 15 miles each way. Up and down hills back-roads, stop lights etc. from 25 to 65 MPH.
Came home and used a laser temp meter and found these temps on the engine. I dont know if thats good or bad? Top of radiator - 120 degrees Top of Thermostat Housing - 191 Under the Thermo housing - 171 Head between first 2 exhaust ports driver side - 192 Front of head - 191 Block - 191 Temp Gauge reading (Lectric Limited sender for year model gauges): So what do you think?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-10-2021 at 03:53 PM. |
#542 | |
#543 | |
Moderator
#544 |
What temp range thermostat are you running?
#545 |
Moderator
180
#546 |
I have the same exact readings.....I feel better too...lol...
#547 |
I would expect around/within 15° of the thermostat opening point.
#548 |
Moderator
So 11 degrees is good huh?
#549 |
My 63 gauge runs about that same degree on the sweep with my 180 thermostat and letric limited sender unless I'm running in 95+ weather when I've been going for a few hour At that point it will sit about in the middle. When I had a 195 thermostat in it, the gauge was almost pegged constantly
#550 | |
![]() Join Date: Sep 2020
Question, is that still an amp gauge, or has it been mod to a volt meter? With what I saw in your engine compartment, I would be using a 100 amp alternator at minimum, if that is an amp gauge, it won’t handle it well…. |
