03-23-2011, 04:54 PM | #1 |
way2lo2
1960-1972 Lowering Block U bolts
I have been reading countless posts concerning people not being able to get longer u bolts (at a reasonable price) when installing lowering blocks for the 60-72 Rear truck arm suspensions. Yes, we all know , if you can find a big truck spring shop, you can get a set made, as long as you know the size, length width etc. We've been stocking these so I figured I'd offer them to members. You get the longer U-bolts to accommodate a 1"-2" block with washers and nuts for $14.95 each. These will fit in a USPS flat rate envelope anywhere in the US for $5.00 shipping. I also have solid blocks in 1" 1.5" and 2" sizes.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 Last edited by way2lo2; 03-23-2011 at 04:56 PM. Reason: typo |
03-29-2011, 01:41 PM | #2 |
Re: 1960-1972 Lowering Block U bolts
No 3" blocks huh?
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
03-29-2011, 02:56 PM | #3 |
67-72 parts collector,…
Thanks for offering up the U-bolts.
Like you said,... we get many members wanting them. I'll send them your way, from now on.
03-30-2011, 08:37 AM | #4 |
way2lo2
I can't say I've ever seen a 3" block in a truck arm application. I guess if there is enough call for it, I will start making them.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote. 216 481-5219 office 216 481-4240 fax 216 789-1647 mobile Way2Lo2@aol.com <----also my paypal http://www.hubgarage.com/mygarage/way2Lo2 |
03-31-2011, 09:28 PM | #5 |
3" block could run into posible scrub line problems ? Read somewhere 1.5 is the max with a 15" wheel
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-01-2011, 01:39 PM | #6 | |
That being said, I've seen more than one guy use 3" blocks w/o problems. It just seems to be an un-worthy risk. Boris, what are you getting for the blocks?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-01-2011 at 01:42 PM. |
04-01-2011, 02:51 PM | #7 | |
way2lo2
2" are $38pr. I will probably run a April special for U bolts, blocks, and hardware.
04-06-2011, 01:23 AM | #8 |
I am looking to lowering my 72' C10 with 2" lowering blocks; Lowering block u-bolts, adjustable panhard bar and a pair of shock relocators.
I already have 3 inch lowered springs. I don't want to c-notch. Please let me know when you are offering the packaged deal. Thanks, Frank juiced66chevelle@aol.com Last edited by nrgtruck; 04-06-2011 at 01:24 AM. |
04-06-2011, 04:13 PM | #9 |
Hey Boris, don't forget to send me those blocks when you get them in stock.
Mike |
04-06-2011, 04:52 PM | #10 |
way2lo2
went out today, thanks again Mike
Boris
04-06-2011, 05:04 PM | #11 |
Awesome!
04-20-2011, 08:56 AM | #12 |
I saw you might be running an april special. Could you PM me a price on the setup for 1.5 inch blocks and the appropriate u-bolts, nuts and washers.
Thanks David
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-29-2011, 11:29 PM | #13 | |
thanks Al
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-03-2011, 12:51 PM | #14 |
Restoration Virgin!
boris....can you make standard length u-bolts for a 71 rear end?? If so, how much for a pair shipped to 27596 with all washers and bolts....Thanks
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-03-2011 at 12:52 PM. |
05-04-2011, 10:55 AM | #15 |
way2lo2
Yes, stock length U bolts are also in stock $14.95 each.
Geoff, yours were shipped to Jesse today. Thanks
05-04-2011, 08:53 PM | #16 |
Restoration Virgin!
thanks so much Boris!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
05-07-2011, 06:47 PM | #17 |
Restoration Virgin!
Thanks again for the quick shipping Boris....Jesse got'em Friday
06-08-2011, 10:47 PM | #18 |
Grandpa in the rustmobile...
Im looking for a 1" or 1.5" drop block for a 68 c10 pickup with coil springs...
Do you have any blocks, or just U bolts? Thanks, and great prices!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-09-2011, 07:53 AM | #19 |
way2lo2
Yes, we have those blocks. PM sent
06-19-2011, 07:07 AM | #20 |
I need a set of 2" block U-Bolts (only the bolts, not the blocks. I stripped an end on mine).
Can you send me payment info? I can pay by Paypal.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
06-19-2011, 08:05 AM | #21 |
way2lo2
06-19-2011, 10:58 AM | #22 |
Paypal'd the money.
06-20-2011, 11:11 PM | #23 |
And im in line for a set of 1 1/2" bolts. PAypay accepted?
Thanks |
06-21-2011, 05:23 AM | #24 |
way2lo2
pm sent
08-15-2011, 04:54 PM | #25 |
How much for 2" blocks, and the U-Bolts combo?
Thanks.
1966 Step C10 |
