Old 05-03-2009, 12:25 AM   #1
GRIMSS
GRIMSS's Avatar
'56 Chevy Panel build (SLP)
Well with the purchase of the suspension I’ve decided to go ahead and start a build thread. I’ll start from the beginning just to document it all on one page.
In high school I would drive buy this little old junk yard that was in a town of around 900. I kept eying this panel that was barely visible.
This was what it looked like from the street.
3rd year of college I decided to talk to the guy and ended up buying it for $50. Turned out to be a ’56 chevy ½ panel. Last time it was on the road from the plate was ’68.
It took 6hrs to get it out of the junk yard and to the farm only 8 miles away. More junk yard shots. It was full of engine parts he was storing. And it was covered in moss.
I used an old axle that my dad had lying around to transport it once out on the farm. Here are pics of it after I scraped most of the moss off.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 05-03-2009, 12:26 AM   #2
GRIMSS
GRIMSS's Avatar
Re: '56 Chevy Panel build (SLP)
Then it sat in the old shed until for 14 years collecting dust.
While it didn’t look like much the panel body has zero rust through. The only rust though is in the typical truck areas, steps, toe board, firewall, and cowl.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 12:27 AM   #3
GRIMSS
GRIMSS's Avatar
Over the last few years I’ve been collecting parts. Now I’m going to start on the first stage of the build, to get it rolling. Here is my rendering I did to inspire me. I look at this every day.
Plans
Suspension front- Scott’s Super Slam IFS, airbags, disc brakes, power rack.
Suspension rear- SD’s Super lift triangulated 4link
Wheels - dodge 20” steel spares, filled holes, and early chevy hub caps
Body- 2 tone paint, slight custom touches here and there but keeping it stock looking
Interior- Keep it simple and looking stock
Motor- ?? don’t know yet leaning toward and LS.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 12:29 AM   #4
GRIMSS
GRIMSS's Avatar
May 1st after work.
I pulled the panel over to the shop to start. Since it was a late start that’s all I got done.
May 2nd
It started off good found 4 used 20’s for $25 on my way to the metal shop. Metal shop was closed, so no metal for the boxing plates. Next I just started to clean the panel out. After 41 years of sitting there was a ton of dirt. I knew that the wood was in decent shape but wow only one small spot that had a little rot.
Here’s more of the clean up.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 12:30 AM   #5
GRIMSS
GRIMSS's Avatar
A few things I never noticed fire extinguisher bracket and flare bracket
Dash has the heater delete and radio delete plates.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 12:31 AM   #6
GRIMSS
GRIMSS's Avatar
Little bit of the fun stuff.
20's” mounted to the s-10 rear.
Now it’s time for cutting up that nice wood floor. You truck guys have it easy, just yank the bed off and there you have it.
Just for fun I rolled the rear end up front to see what it was looking like. Still need lower profile tires and the rockers are still too high.
That’s it for a little while. Since it’s out on the farm 20 miles away, only get to work on the weekends.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 01:05 AM   #7
cajundragger
sweeet.
using adapters in the back?
cajundragger is offline   Reply With Quote
Old 05-03-2009, 06:25 AM   #8
57ToyBox
57ToyBox's Avatar
Nice work Jared
You must be excited to finally get started on the panel. You sure got luck with that shell. Good start. I'll definitely be following closely every weekend
Luv your rendering of the finished product, that gonna be sweet
57ToyBox is offline   Reply With Quote
Old 05-03-2009, 08:51 AM   #9
GRIMSS
GRIMSS's Avatar
Originally Posted by cajundragger View Post
sweeet.
For now I'm using adapters. Later on I will probably build a rear with out them.
Very excited about the start. Like I said been setting on this thing for 14 years plus the 5 years from when I first saw it. And yes deals like that are getting harder to come by.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-03-2009, 11:10 AM   #10
stan3018
keep it up man .....
stan3018 is offline   Reply With Quote
Old 05-03-2009, 10:33 PM   #11
JML55
JML55's Avatar
Nice work, i like it with the 20" looks rely good. Keep the pictures coming.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 05-04-2009, 09:23 AM   #12
entourageguy
Yellow truck club
entourageguy's Avatar
Have you finished up a wheel and tried to balance it yet. I remember seeing a thread about you doing this with the wheels and wondered how it worked out?
Neat build......
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-04-2009, 03:01 PM   #13
OLDIRON69
subscribed..
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 05-04-2009, 05:55 PM   #14
GRIMSS
GRIMSS's Avatar
Neat build......
Not yet. Still need to do a little grinding on the test wheel.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-05-2009, 12:34 AM   #15
cajundragger
they will balance. You'd seriously have to bend the wheel for it to not balance.
you'd be freaked out if you saw how actually out of round and horribly off weighted 99% cast chrome wheels are.
Old 05-05-2009, 07:12 PM   #16
alden
alden's Avatar
what are the wheels off of? looks like some great progress!
alden is offline   Reply With Quote
Old 05-05-2009, 09:07 PM   #17
GRIMSS
GRIMSS's Avatar
Wheels are newer 20" dodge truck spare tires.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-05-2009, 09:13 PM   #18
CG
BlahBlahBlah
Lotta nice ideas going together here. 56 panels are very cool.
Old 05-05-2009, 09:40 PM   #19
57ToyBox
57ToyBox's Avatar
Any progress on the cab?? I have to ask... Why did you have to cut the floor out??
and which S10 rear axle did you p/u for your truck?
Old 05-05-2009, 11:05 PM   #20
GRIMSS
GRIMSS's Avatar
Thanks, been thinking about this thing for a while now. With all the stuff going on today it's getting harder to come up with something different.
Nope, only working on it on the weekends. Just did some major cleaning and assessing the rust damage.
Cut the floors for my 4link. With the size of tires and how low I'm going it had to be done.
This is a 2wd S10 rearend. I did checking and since I had to run addapters it was going to work for me. I plan later to build a rearend that will do with out the addapters and be wider.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-06-2009, 04:45 AM   #21
alden
alden's Avatar
good deal, thanks!
Old 05-06-2009, 03:32 PM   #22
pugs
pugs's Avatar
ck the width of a mustang or cougar they mite be what you need
the body looks real decent from what we see
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 05-06-2009, 06:56 PM   #23
71'tahoe
71'tahoe's Avatar
I love it!!
71'tahoe is offline   Reply With Quote
Old 05-10-2009, 08:51 PM   #24
GRIMSS
GRIMSS's Avatar
Big fat zero done on the panel this weekend. Wife birthday, mothers day, and nephew's dedication used up my whole weekend. And found out that next weekend is loaded up also.
I did go out to the farm to check on it after some nasty storms rolled through the area the other night.
2001 GMC SIERRA
1968 Camaro
Jared
Old 05-10-2009, 11:48 PM   #25
OrrieG
OrrieG's Avatar
I understand my weekend was honey doos involving the cabinet making part of the shop. Next week end I'm traveling to my Mother's memorial service. But after that I get to finally prime and paint all the stuff I worked on this winter and get to finishing the body work. Did have a nice mothers day BBQ over at my kids.
