Heavy oxidization on alluminum rims....
I went out and got some mothers aluminum polish and a power ball. the first rim I did started to clean up nicely but it takes a long time. I was hoping that with everyone's infinite wisdom that you would have some easy cheap ticks to get it all off with out so much of a fight. Maybe coke?.. if the pictures come out well you will see what im talking about. thanks
Re: Heavy oxidization on alluminum rims....
i'd start with a brillo soap pad cheap easy to use and does a good job for the first step
will the brillo pad scuff it uf really bad?
ask your mom she's probally been using them since b4 you were born
Under Construction
use this 1st
http://www.californiacustom.com/alum...eoxidizer.html then this http://www.californiacustom.com/purp...al_polish.html those rims may be clearcoated... which means they would probably have to be stripped to be cleaned up really well...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 03-12-2010 at 06:14 PM. |
steel wool use the real fine stuff it will shine it right up
![]() ![]() '82 ![]() (Hot Rod) '90 ![]() (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
Parts and more parts
The statement above about the California Custom aluminum deoxidizer is a good one. That stuff works real well. However it has limitations just like many other things. If all fails get a die grinder (electric or air driven) and put a tapered spindle in it and use some small "Razor Buffs" and a set of polishing bricks. I use a black rouge to cut the nasty stuff first, then a green rouge to polish and white rouge to give the metal a final color. A lot of that stuff can be found at the Eastwood website or even go to your local truckstop---they usually sell it to the drivers for their trucks. Sears or harbor freight has small bricks, also.
Razor buffs are a little harder to find but they are out there. Try this outlet for what I am toalking about. http://www.woodworkingshop.com/cgi-b...adItem=FO33906 Get the 4" or smaller ones so that the die grinder works them easy and it lets you get into tight places. Do the owrk with a different buff for each type of rouge. Put very little pressure on the buff as you use it. Try it on your fingernail first---that is as hard as you need to apply it ot the wheel. You can clean four wheels in an afternoon.
Frank |
C-10 Club Member
This stuff is supposed to work amazing.....
I know alot of guys in the west coast boat community that swear by it. http://www.metalwax.com/ I am going to order up there starter kit shortly ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
There is some stuff that I got at my local parts guy that is called "Colonel Brassy" it is some damn amazing stuff that works on all metals. I took an antique Fire Extinguisher that looked horrible and within a couple hours it is in show room quality. Just my .02
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
Slots go on anything!
I have had good luck with the Meguires "hot wheels" aluminum polish also.
1974 Jimmy- 5.3/4L80e/NP241 |
Grandpa in the rustmobile...
hit it with eagle 1 etching mag cleaner THEN mothers! worked on my slots pics in thread
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
"GO DAWGS"
I have used a bunch of stuff in my day and the two that said California custom are 100% correct. I have never seen anything that works as well as this product. I use it on my weld wheels.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
![]() Join Date: Feb 2001
California Customs blows Mothers away. When you get your wheels looking nice you don't have to use the oxidizer. I may use it once a year.
the pollock
the steps are as follows. i have a awrite up in the "how to section" also..
i think ill do one for rims one day step by step. FIRST remove rim from truck and scrub with soap and water, then scrub with a medium brillo pad to remove all the surface dirt and grime. that will be your biggest improvement. (the DIRT and crap will stay in your mothers ball if you use that first.. and will destroy it) NOW, if the rims need any touch ups dont use below 400 grit, i recommend a 800 1000 1500 g step up (only if the rims NEED a severe corrosion removal) if there are creases you can get the filt and dirt out of use a new brass brush soap and water to get in there BRASS BRUSH (steel brushes will marr the rim) now you can either use your mothers ball or a DA witha cutting or finishing pad with some 3M rubbing compound buff the whole rim with that this will remove any residual filth and what not the brillos diddnt get. now the rim is prepped for final polishing, use your mothers aluminum polish and FOLLOW the DIRECTIONS..... it's a messy dirty dirty process so wear shoes you dont like and dont do it near stuff you want to keep clean and GOOD LUCK! PM me if you want anything more specific.
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
