Old 10-20-2010, 10:06 PM   #1
vanceman
Disc Brake Conversion Who Has The Best????
I am going to do a disc brake conversion on my 70. I have been looking at different places such as POL, CPP, GMC Pauls, Early Classics. They all offer different parts and different prices. Iam wanting to know who you went with and how you would rate the product. Who has the best kit at the best price????
vanceman is offline   Reply With Quote
Old 10-20-2010, 11:07 PM   #2
70 net440
Junior Member
70 net440's Avatar
Re: Disc Brake Conversion Who Has The Best????
I used the ECE kit on my wife's '63. Very complete kit. The hardest part was the brake lines. The rest was simple bolt on.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 10-20-2010, 11:32 PM   #3
pat 70/71
pat 70/71's Avatar
I have three trucks and used ECE drop/ disc kits on two of them. 70/71/72 No problems at all. fit was perfect and Stan / Mark /Jeff are more than happy to answer any questions you may have.( great company ) and they stand behind everything they sell. give them a call! straight shooters. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-21-2010, 12:35 AM   #4
78bronzechariot
78bronzechariot's Avatar
I used POL with the drop spindles. The kit was good, all the parts were high quality and it went on in a day. The only thing that I didn't like was that the kit was that it made it impossible to run 15" wheels wider than stock up front. The wider aluminum wheels the PO put on would hit the lower control arm when the wheel was turned all the way over. I had planned on changing to chrome steelies anyway, so it wasn't an issue for me. (except for having to buy them sooner than I had planned ). However, there may not be an issue if you don't run drop spindles, or go with 17s or larger.
78bronzechariot is offline   Reply With Quote
Old 10-21-2010, 10:45 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I used ECE with drop spindles. I run 15x8's with a 4-inch backspace and there has never been any issue with clearances. When you convert to disc, you will have to purchase spindles. If you want to lower it, now's the time.
ECE customer service is outstanding. Those guys (Stan, for instance) will answer questions at almost any time.
Member Nr. 2770
Old 10-22-2010, 05:51 PM   #6
vanceman
Looks like ECE has the vote here. My question is, are ECE kits $200 better then the others? The GMC Paul's kit looks like same components for $200 less. Has anyone used one of the GMC Paul's kit?
Old 10-22-2010, 10:27 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Sure they have. Do a search and see what you get. Seems like I saw one just last week.
Member Nr. 2770
Old 10-23-2010, 12:03 AM   #8
mikewarme
Mine is a 69 3/4 ton. Went to the junk yard and got spindles from a 73 3/4 ton for $15ea. Had them blasted and powder coated $50. Got new aftermarket rotors $50 ea and 2 reman calipers $35 ea. New hoses $35 ea. and got the brake line conversion kit which is incomplete no matter where you buy it. Made my own missing piece. Better than any kit unless you need dropped spindles!
Note the spindles are the same from 71-79 I believe. I did new ball joints at that point. They are diffrent than for drum brakes anyway.
NOBODY sells a 3/4 ton conversion!
mikewarme is offline   Reply With Quote
Old 10-23-2010, 02:21 AM   #9
Beat68CST
Beat68CST's Avatar
I have a 68 3/4 ton, could I use those same spindles and parts from a 79 or older to do the front disk brake conversion?
Beat68CST is offline   Reply With Quote
Old 10-23-2010, 07:52 AM   #10
69 GMC LWB Pickup
I recently purchased a four wheel disk conversion for my 69 GMC LWB from CPP. It's not a bad setup and the cheapest that I have found. Some of the install has been a real PITA because they say it should just bolt right up and fit perfectly but, that has not entirely been the case for the rear brakes. I'm not quite finished with the install on the front so I don't know what to say yet about that. If I had to do it all over again, I would have went with a Wilwood brake system. It is much more expensive but well worth the money and believe me, Wilwood IS just bolt on and go.
69 GMC LWB Pickup is offline   Reply With Quote
Old 10-23-2010, 10:09 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Another support for ECE...
IMO the money is worth receiving all the parts at once and knowing they will fit the way they are supposed too.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-23-2010, 10:51 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
You don't mention drop spindles.
That will make a difference in the direction I would take.
If NO drop spindles are in your plans,... I would just use 73-87 oem disc brake stuff.
If you plan on drop spindles,... spend the money and go with "year specific" spindles (67-70, 71-72, or 73-87) and use ECE.
No need to change ball joints or tie rods.
Keith
Convert to disc brakes.
Old 10-23-2010, 11:09 PM   #13
GMCBubba
GMCBubba's Avatar
http://www.classicperform.com/Store/...6370SWBK8S.htm
they say they have it in 8 lug application. for rear 8-lug conversions, blackbirdcustomtrucks.com looks pretty good
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 10-24-2010, 09:00 AM   #14
vanceman
Yes, I will be going with 2 1/2" drop spindles. What year are the rotors, calipers, and pads on the ECE kit, can I get replacements at a local auto supply?
Old 10-24-2010, 09:36 AM   #15
lolife99
lolife99's Avatar
The rotors are 1.25" wide version easily found at your local parts store.
I'm not sure on the calipers. They are either the 71-72 or 73-87 version.
Either way,... calipers and pads can be found locally.
You will also need to change your master cylinder and proportioning valve.
(which is included in the ECE kit)
Keith
Old 10-24-2010, 10:31 AM   #16
skeeterbug
skeeterbug's Avatar
when i put dropped spindles and four wheel disc on my 71 the original 15" wheels would NOT fit. the wheel rubs the lca's, you will need to upgrade to larger dia. wheels. hope this helps.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 10-24-2010, 10:37 AM   #17
lolife99
lolife99's Avatar
Not necessarily.
ECE sells a 2.5" drop spindle,... like most other "direct fit" spindles.
The old Belltech 3" drop spindles cause more problems.
Either way,... trimming the lower control ares is almost a must, for 15" diameter wheels with more than 3.5" of backspacing.
Keith
Old 11-08-2010, 10:19 PM   #18
chopttop
Junior Member
chopttop's Avatar
I have a '70 1 ton dually,cab/chassis w/Franklin motor home on frame, would like to upgrade to disks, I have read much on this and the complete crossmember swap looks like the best way to go , could I use a C20 crossmember ? Thanks in advance
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline   Reply With Quote
Old 11-09-2010, 08:03 PM   #19
mrhino
I used everything for a 73, on my project i'm working on, rotors, calipers, pads, banjo bolts, bearings, seals, spindle nut,washer, cotter pins, even those little brake hose clips. everything got it from my local parts house. except the steel braided brake hoses, and spindles, I used CCP drop spindles. They sell them through ebay and if you wait till the weekend they take another 10% off. (at least they use too). it saved a bunch over one of the so called "kits".
did the same for the rear as well bought everything seprate from advance. even the 4 wheel disc M/C. the proportioning valve came from the internet. If you are running rear drum brakes. do a search for PV2 and if you want 4 wheel disc search PV4 you can find the for about $50 or so. I probably have less in my whole brake system then what one front "kit" cost. However Im not running a E-brake so that save some money there.
mrhino is offline   Reply With Quote
Old 11-09-2010, 09:41 PM   #20
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
www.abspowerbrake.com looks affordable.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-15-2020, 08:43 AM   #21
HeyRed
I’m hoping to open this conversation again since it looks like ECE (the highest recommended PB conversion kit on here) has gone out of business permanently.
I’m converting to power disk up front on my 67. I want a complete, no-hassle kit. I don’t want cheap...I want a very strong product. Ive got these two on my radar:
http://https://www.cjponyparts.com/m...-1970/p/DBF61/
And
http://https://www.performanceonline...ck-5-or-6-lug/
Has anyone had experience with either of these products/companies good or bad?
Is there a new kit/company out there that I’m missing that I should check out?
Also, as a side note...anyone ever had an issue with shift linkage when converting to power brakes? I was daydreaming yesterday staring at the firewall and man...it looks like the linkage off the column is right where the booster needs to go.
Thanks!
HeyRed is offline   Reply With Quote
Old 11-16-2020, 11:35 AM   #22
MDPotter
MDPotter's Avatar
I got mine from POL and have no complaints.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-16-2020, 01:20 PM   #23
HeyRed
Right on. I haven’t been able to get a hold of anyone at POL either in tech support or sales with a question.
I’m running stock 15” wheels (obviously drum) and want to make sure that the wheels will fit with this kit. If you’re running something similar, did you have to do any “fine tuning”? Grinding on the caliper, etc....?
Old 11-16-2020, 01:48 PM   #24
MDPotter
MDPotter's Avatar
I didn't have to do any modifications, but I am running 17" wheels. I know there is a disclaimer about 15" wheel clearance being a potential issue. I'm sure it depends on offset/backspace and the wheel itself.
Old 11-16-2020, 02:52 PM   #25
gmc684x4
One area of fitment issues on disc brake swap is some drum brake 15 inch wheels have a lip in the back space area that rub the calipers
If there newer aftermarket wheels should be ok
gmc684x4 is offline   Reply With Quote
